I use ASP mostly in the file system mode. The problem is that it tries to rescan the last directory used which take "forever" especially if that directory has thousands of images.
- Is there a way of starting at a fixed directory? Or setting the startup directory from the command line as a switch?
- I use Ubuntu 10.04 Lucid and there's no man page for aftershotpro. Is there a list of the command prompt switches?
