I'm new here and also new to use VS.
I've met an issue that has been raised years before, but I couldn't find a "solution" in the earlier posts.
http://phpbb.ulead.com.tw/EN/viewtopic. ... d65283b5bf
http://phpbb.ulead.com.tw/EN/viewtopic. ... 624#p96774
What I'm doing is trying to CUT some XVID video and save them with their original format via the following steps:
Share > Create Video File > Same as First Video Clip. The progress will go through to 90%, then I will get the error message:
Unable to compress the audio
[17103:10:5]
Decompress the original won't be a choice when hundreds tasks are out there.
The detail infomation about the video I'm working on, hope it will provide more details.
Thanks in advance!xxx.avi
General
Complete name : xxx.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 232 MiB
Duration : 23mn 19s
Overall bit rate : 1 388 Kbps
Writing application : Nandub v1.0rc2
Writing library : Nandub build 1852/release
Video #0
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 23mn 19s
Bit rate : 1 247 Kbps
Width : 704 pixels
Height : 396 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.187
Stream size : 208 MiB (90%)
Writing library : XviD 1.0.3 (UTC 2004-12-20)
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 23mn 19s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 21.4 MiB (9%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 480 ms
