Download ASP on Linux
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: Download ASP on Linux
Post by afx »
The official Corel download page does not work here either (FF in Ubuntu). I get some sort of a a popup where I only see the close button....
Same behavior on Chromium.
cheers
afx
greerd
System_Drive: Z
processor: Intel i7 920
ram: 12 GiB
Video Card: nVidia GeForce 260
sound_card: Onboard
Hard_Drive_Capacity: 5 TB
Monitor/Display Make & Model: Dell UltraSharp U2410
Post by greerd »
grooveman wrote:
pgman wrote:I'm on Ubuntu 10.04, 11.04/FF 10 and 11 and it works for me. It also works on Google Chrome 17 and 18 and finally on Opera 11.6x.
Most likely you are either using noscript or have disabled the javascript on Preference > Content tab.
Can't speak for anyone else, but this is definitely not the case for me. I do not use noscript, and javascript is definitely enabled. It bombs out on my two debian squeeze boxes and my Gentoo box, on Iceweasel and Firefox (3.x, 10.x and 11.x), it also fails on opera and Konqueror. All I get is a dimmed-out screen with a floating "X" to close the window that isn't showing...
I wonder if you are using icedtea instead of jre? I've run into issues before with icedtea that forced me back to jre.
Hobgoblin
System_Drive: N/A
Post by Hobgoblin »
May I suggest those who have these problems make a note/Bookmark of the url's I posted earlier or use the Upgrade Page.
http://www.corel.com/corel/pages/index. ... id=4300004
These are for the latest version 1.0.10.1
Personally I would prefer simple HTML Links for these sort of things, not 'cool' but very effective and Cross Platform Compatible.
R.
thufor
System_Drive: B
Post by thufor »
greerd wrote: I wonder if you are using icedtea instead of jre? I've run into issues before with icedtea that forced me back to jre.
There sure is an awful lot of Javascript on that page but I haven't seen any Java stuff.
spoilerhead
System_Drive: N/A
Hard_Drive_Capacity: 13.5TB
Post by spoilerhead »
Not working for me in Austria on ubuntu 11.10 x64 in Firefox, chromium, epiphany.
my ASP Plugins - donation button ( send beer! :) )
linux,7d, glass and a huge mug of coffee.
If you got any immediate problems with my plugins, don't by shy on contact me on GoogleTalk.
grooveman
System_Drive: N/A
Post by grooveman »
greerd wrote:I wonder if you are using icedtea instead of jre? I've run into issues before with icedtea that forced me back to jre.
This was my first thought as well, but after downloading Sun java, and switching my system and user vm to it, it still does the same thing. A good guess... but aparently... wrong :(
So, it doesn't seem to matter if I use iced-tea or Oracle/sun java. I don't think that Ajax requires a javavm anyway, so I think the problem must lie elsewhere...
spoilerhead
System_Drive: N/A
funny enough: it also doesn't work on my android phone (Android 4.0 browser) ;-)
Zarastro
System_Drive: N/A
motherboard: M4A89TD
processor: AMD Athlon X6 1075T
ram: 16 GB
Video Card: Point Of View GeForce GT 620 1024MB
Hard_Drive_Capacity: 1300 GB
Monitor/Display Make & Model: Dell WA2209
Post by Zarastro »
I went almost crazy trying to download the file, and then I've noticed that the Corel page was set to Brazil.
You must set the Corel page to United States (at right upper corner on the site). If you don't do this, you won't be able to download ASP.
afx
System_Drive: N/A
Post by afx »
Zarastro wrote:You must set the Corel page to United States (at right upper corner on the site). If you don't do this, you won't be able to download ASP.
That does not fix the Linux Download issue....
cheers
af
FrankX
System_Drive: X
Post by FrankX »
No problem under Ubuntu 10.4 with Firefox ;-)
madsec
System_Drive: N/A
motherboard: Macbook 5.1 - Intel based
processor: Core 2 Duo 2.0 GHz
ram: 8 GB
Video Card: Nvidia Geforce 9400 Go
Hard_Drive_Capacity: 750 GB
Monitor/Display Make & Model: Macbook 5.1 - 13 inch
Post by madsec »
No, changing the country to United States doesn't fix the problem. Anyway, the download link posted in the update notification works fine, the link leads to the support area of the Corel site. Here is the post: http://forum.corel.com/EN/viewtopic.php?f=90&t=46138
pgman
System_Drive: N/A
[Solved] Re: Download ASP on Linux
Post by pgman »
pgman wrote:
hochglanz wrote:Is anyone able to download ASP on an Linux computer? If I click on the download button a new window appears which consists only of a "top bar with close button".
Please can you provide a simple download button which works?
I wrote this on 15-Apr-2012 and it worked then (for me). On 20-Apr-2012, I tried downloading ASP with a Linux Firefox 11 and it did not work. To make it work, I had to the "User Agent Switcher" with a setting of Internet Explorer and the download worked. UAS allows Firefox to be identified as something else.
Posted for other people information.
boogie
System_Drive: N/A
Post by boogie »
edit: Sorry, didn´t notice the previous post
the Firefox extention "User Agent Switcher" solves the problem with Corel´s (and many other) websites.
Choose "Internet Explorer 8" and reload the download page.
The addon can be found here https://addons.mozilla.org/en-US/firefox/extensions/ (search for user agent switcher)
kind regards
Gabi
grooveman
System_Drive: N/A
Post by grooveman »
boogie wrote:edit: Sorry, didn´t notice the previous post
kind regards
Gabi
Confirmed. I guess this means corel needs to do a better job of checking for cross-browser/cross-platform compatibility... But at least you gave us a good work-around boogie! Thanks.
G
Jeff Stephens
motherboard: several
processor: Opterons and Atoms
ram: Bunches
Video Card: something cheap
sound_card: on board
Hard_Drive_Capacity: pretty big
Monitor/Display Make & Model: several
Post by Jeff Stephens »
grooveman wrote:Confirmed. I guess this means corel needs to do a better job of checking for cross-browser/cross-platform compatibility... But at least you gave us a good work-around boogie! Thanks
It certainly does, but in the meantime, there's a link that DOES work for linux folks now:
Who's clever enough to spot the new link? :P
Cheers, Jeff
