VSX5 Ultimate unspecified error-Clean up utility
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
I am trying to install Windows Cleanup Utility from the following link to cure an unspecified error due to a temp file in the hope of stopping this happening again.I have done a disc clean up and deleted temp files manually.
ftp://ftp.corel.com/pub/Installer/MSICleanup.exe
This does not work……”.problem loading page “ Is there another working link to access this ?
Ken Veal
ram: 32 GB
Re: VSX5 Ultimate unspecified error-Clean up utility
Post by Ken Veal »
Sorry, I managed to post this twice!
Second post deleted
yes the link worked for me.
What actual problems are you having, as you have just installed X5
Hi Kenneth
I don't know where you found that file but it is not dedicated for X5. Take care in using these files.
If the normal Add & Remove options do not uninstall the program then use the Clean-Up provided by Corel from the Knowledge Base.
Ken Veal
ram: 32 GB
Post by Ken Veal »
It came up with" problem loading page£ after something like" it had to be reset" Any way,I ctrl clicked the link in the above post and made a little more progress,I was able to save the file.But on opening it a box titled ZapMSI only gave me the option of cleaning up Paint Shop ProX
Hi Kenneth
go to your computers Control Panel
Select Add and Remove Programs
Use this panel to un-install your Corel programs.
Other options............
If you try to install the program without un-installing it, you should be prompted to un-install first.
Only use the Clean-Up files provided by Corel when you are unable to un-install using the above options.
To download the clean-up file, do so via the Knowledge base, that way toy will get the correct file for your product.
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
I'm not sure if MSICleanup.exe will work with VS X5. I suggest that you first uninstall via the ADD/REMOVE PROGRAMS of Windows XP, since that is the best and easiest way to remove an installed program.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
Ken Veal
ram: 32 GB
Post by Ken Veal »
Thank you Trevor and Abiel for the replies, inview of what you have said and the fact that I am not actually having the porblem now after deleting all temp files, I think I will leave things as they are or I will get into more trouble.............Ken
