out of memory,,,
LinuxSam
operating_system: Linux
System_Drive: N/A
motherboard: Gigabyte x58a-ud3r
processor: i7-980
ram: 12Gb
Video Card: Gigabyte GTX460 1Gb
Hard_Drive_Capacity: 2Tb
Monitor/Display Make & Model: Dell U2410f
out of memory,,,
Post by LinuxSam »
I used to have this problem in Bibble 5 too..
When looking through folders, with lots of images, I now an then get a popup that says "Bibble is unable to allocate more memory and will now quit" And obviously they haven't changed the error message since the change of the name.
I'm now running Debian GNU/Linux 64bit with 12Gb of RAM and in no way is Bibble/ASP out of memory...
Anybody else get this error and do you know what causes it? How to fix it?
/LinuxSam
Linux IS user friendly, it is just selective about who its friends are.
greerd
System_Drive: Z
processor: Intel i7 920
ram: 12 GiB
Video Card: nVidia GeForce 260
sound_card: Onboard
Hard_Drive_Capacity: 5 TB
Monitor/Display Make & Model: Dell UltraSharp U2410
Re: out of memory,,,
Post by greerd »
You might want to go into Preferences - Import & Cache and check your current cache size. Perhaps increasing the Target size will help, especially when in File System.
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
Of course it is out of memory.
No matter how much memory your 64bit box has, a 32bit app is still limited by the 4GB barrier but practically that is closer to 3GB.
While the last release of B5 fixed loads of memory leaks, looks like there is still one active, so it runs out of memory or stumbles across its ownfeet trying to juggle memory allocation (though that is typically a Windows problem).
Cache size is irrelevant for memory usage.
But, having all images cached and not needing preview generation will help memory usage by avoiding preview generation runs that could use up memory
cheers
afx
Dutchmm
System_Drive: N/A
motherboard: Asus 97
processor: Intel i7 4785T
Video Card: Onboard Intel
sound_card: Intel AC97
Hard_Drive_Capacity: 2.5TB
Monitor/Display Make & Model: Philips 28"
Corel programs: ASP 3 Pro (and 2 and 1 before)
Post by Dutchmm »
As we have been discussing in another thread, ASP is still compiled with the 32 bit libraries even in the so-called 64 bit versions. I have pointed this out to the Corel techs, so we may hope that they will produce a genuine 64-bit version at some point in the future.
