Screen capture in X5 Pro Ultimate
Re: Screen capture in X5 Pro Ultimate
This is a screen shot of the capture the frame size adjusted a little larger than X5 interface to show a border.
It recorded as set.........
click image for larger view
Kingston
motherboard: Gateway [Acer] DX4860
processor: Intel Core i5 3rd gen. 3 GHz
ram: 8 GB
Video Card: Intel HD 2500
sound_card: Bluetooth
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Post by Kingston »
Trevor and I have Windows XP Pro, and neither of us are having problems capturing. It could be a Windows 7 or 64-bit compatibility issue.
when i can get to the wifes laptop i will give it a go, but when i last used it i did not have a problem, but need to re-check
Using Windows 7 (Lynn is washing up)
Just captured the X5 workstation with no problems.
My captures recorded everything within the customised window and nothing else.
set at 1030 x 576, thats what it recorded, i would normally select 1280 x 720 for my frame size purley to create a standard video size.
It seems to work as it should
Kingston
ram: 8 GB
Post by Kingston »
Have you tried installing the latest graphics driver for your graphics device? I always try installing the latest graphics driver for my NVidia card when I have screen issues.
e_a_g_l_e_p_i
motherboard: MSI MAG Z790 Tomahawk WiFi Gaming Motherboard
processor: Intel Core i7-12700KF Desktop Processor
ram: 32GB
Video Card: Gigabyte GeForce GTX 1060 Windforce OC 3GB GDDR5
sound_card: onboard
Hard_Drive_Capacity: 10 TB
Monitor/Display Make & Model: Dual 24 inch Samsung Monitors
Corel programs: VideoStudio Ultimate X10,PaintShopProX9
Post by e_a_g_l_e_p_i »
Yes my graphics card drivers are current. I guess I will call Corel Monday....so much for calling Corel, they do their best to avoid giving support and direct you to a paid base support system EVEN THOUGH I am still within my 90 days.... which I should get free support.
e_a_g_l_e_p_i
ram: 32GB
sound_card: onboard
lata wrote:Hi
instead of capturing the X5 work space try capturing something on a webpage, after all why would you want to capture the X5 work space unless doing a tutorial on X5. The capture feature is more likely to be used on websites or desktops.
Kingston
ram: 8 GB
Post by Kingston »
I, Kingston, did capture some video playing on YouTube. That came out correctly. I drew the rectangle just around the player.
e_a_g_l_e_p_i
ram: 32GB
sound_card: onboard
Kingston wrote:I, Kingston, did capture some video playing on YouTube. That came out correctly. I drew the rectangle just around the player.
Notice that those who have no issues all have Windows XP?
Hi e_a_g_l_e_p_i
I have also run some tests using Windows 7 without problems.
You Tube capture worked fine, no problems. Any capture I try seems to work without problems.
I have tried in vain to replicate your problem.
It should not matter what we are capturing, we are just capturing the screen pixels irrespective of the source
I cannot try W7 at the moment, till I re-install, having problems installing X4 after X5, so I uninstalled all last night, will re-install X4 first, I digress..........
I will try to do a screen capture of the X5 screen capture process I use, if that makes sense, although I cannot believe you are doing anything wrong, you just cannot get it wrong, it just works??????
Post by BrianCee »
Well I have Windows 7 Premium on the laptop and Windows 7 Ultimate on the Desktop and both use the VS screen capture with no problem at all - the problem is the screen capture has only just been included and we have not found out enough information yet about what makes it work and what stops it working.
e_a_g_l_e_p_i
ram: 32GB
sound_card: onboard
You would think Corel would have done that in R&R before releasing it.
I am going to uninstall VSP and then reinstall it and see if that helps, other that that I will wait to hear back from Corel which I hope will be before they lower me in the grave.. ie, they are slow
I am back up and running on the laptop with W7, screen capture is still performing ok.
e_a_g_l_e_p_i
I noticed from your profile that you are running Dual monitors, have you tried disconnecting the second monitor and running on one??
Post Edited
I have just tried Dual Monitors, no problems, using XP
e_a_g_l_e_p_i
ram: 32GB
sound_card: onboard
lata wrote:Hi
e_a_g_l_e_p_i
Post Edited
Yes I tried using only one monitor and the same problem, reinstalled it and same problem
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
Rather than using the screen capture of VS X5 to copy a youtube video, I would suggest that you try using a youtube downloader that will allow you to download the video file directly from Youtube. Real Player has a feature to do that and there are a lot of FireFox and Chrome extension that allows you to download video from Youtube.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
