If I use Straighten and then Crop, I often get a little corner remnant from outside the original image.
Why can't I Clone into this area?
I can with PSP.
EDIT: Solved using zPerspector "Mirror" as suggested by Ogrizzo
Why can't I Clone outside the original image? [solved]
Tadjio
- motherboard: Gigabyte
- processor: Core i7 2.8GHz 860
- Video Card: ATI HD5570
- sound_card: Sound
- Hard_Drive_Capacity: 2.5TB
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
kaymann
- motherboard: ASUS P8P67 PRO REV 3.1
- processor: Intel i-7 6800K
- ram: 32 GB
- Video Card: NVidia GeForce RTX 2060
- sound_card: Onboard
- Hard_Drive_Capacity: 3.5 T
- Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
- Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
Re: Why can't I Clone outside the original image?
Screen shot to see your results?
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Because AS is not a pixel editor...Tadjio wrote:If I use Straighten and then Crop, I often get a little corner remnant from outside the original image.
I can with PSP.
cheers
afx
Tadjio
- sound_card: Sound
Your wish is my command... All I would like to do in this sample image that I have Rotated and Cropped is to Clone the sky into the top right-hand corner.kaymann wrote:Screen shot to see your results?
A piece of cake with PSP!
Tadjio
ogrizzo
- System_Drive: Q
- processor: 2.8 Ghz Intel Core i7
- ram: 8 GB
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Integrated Apple iMac 27"
Just use zPerspector to rotate and select 'Mirror'Tadjio wrote: All I would like to do in this sample image that I have Rotated and Cropped is to Clone the sky into the top right-hand corner.
Tadjio
- sound_card: Sound
Thanks, Ogrizzo! I had never tried "Mirror" before and it works a treat - very easy indeed. Just one question - what is the purpose of the "Pixel Offset for Mirroring Edges"?ogrizzo wrote:Just use zPerspector to rotate and select 'Mirror'Tadjio wrote: All I would like to do in this sample image that I have Rotated and Cropped is to Clone the sky into the top right-hand corner.
I have bought tin.tin a couple of beers for his efforts
Tadjio
kaymann
- ram: 32 GB
The highest offset you can go to is 99. The offset is the area where the mirror starts its transition and it appears the higher the offset the smoother the "line" where the mirror begins. In you example a nice low offset is very appropriate in others not so much.Tadjio wrote:ogrizzo wrote:Tadjio wrote: Just one question - what is the purpose of the "Pixel Offset for Mirroring Edges"?
Tadjio
- sound_card: Sound
Thanks. Presumably that is measured into the image from the edge. With a 4000 pixel image it can't make much difference.kayman wrote:The highest offset you can go to is 99. The offset is the area where the mirror starts its transition and it appears the higher the offset the smoother the "line" where the mirror begins. In you example a nice low offset is very appropriate in others not so much.Tadjio wrote:Just one question - what is the purpose of the "Pixel Offset for Mirroring Edges"?
Tadjio
tintin
- processor: Ryzen R5 3600X
Re: Why can't I Clone outside the original image? [solved]
the "Pixel Offset for Mirroring Edges" is the offset in pixels to start the mirroring effect from the edge inside the image. this option is needed for perspective corrected images. if the mirroring is enabled with offset zero you'll see some artifacts on the edges. the 3 as default is just the value that I found as a 'best practice' value. but it might be increased to adjust the mirroring line(s).Tadjio wrote:Just one question - what is the purpose of the "Pixel Offset for Mirroring Edges"?
br,
tintin
