Thumbnail panel layout
buntu
- System_Drive: N/A
- motherboard: Asrock
- processor: X270
- Video Card: GF210
- sound_card: SBx00 Azalia
- Hard_Drive_Capacity: 5GB
- Monitor/Display Make & Model: Viewsonic, HP
After selecting an image folder I see all the thumbnails in a _vertical_ panel at the left side. How can I change this? I want to see all the thumbnails horizontal aligned, like it was with bibble.
I use Aftershot with http://xubuntu.org/
Tadjio
- motherboard: Gigabyte
- processor: Core i7 2.8GHz 860
- Video Card: ATI HD5570
- sound_card: Sound
- Hard_Drive_Capacity: 2.5TB
Re: Thumbnail panel layout
In the View Menu, use "Toggle Orientation" (Ctrl+L)
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
Tadjio
- sound_card: Sound
Curiously, whenever I install a PlugIn, the orientation reverts to Horizontal.
I always toggle it to Vertical, which is preferable with a wide screen.
Tadjio
claudermilk
Same here, though it seems to revert every time I load ASP. Very irritating. I want them to stay vertical.Tadjio wrote:Curiously, whenever I install a PlugIn, the orientation reverts to Horizontal.
Bibble transplant
Tadjio
- sound_card: Sound
They always remain Vertical for meclaudermilk wrote:Same here, though it seems to revert every time I load ASP. Very irritating. I want them to stay vertical.Tadjio wrote:Curiously, whenever I install a PlugIn, the orientation reverts to Horizontal.
Tadjio
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Hmm, that sounds like AS can not write the Qt config....claudermilk wrote:Same here, though it seems to revert every time I load ASP. Very irritating. I want them to stay vertical.
If I remember correctly you are on Windows, so it might be a registry key that has the wrong permissions.
cheers
afx,
ferdinand-paris
- motherboard: GA-X58A-UD3R
- processor: 3.20 gigahertz Intel Core i7 960
- ram: 4Gb
- Video Card: NVIDIA GeForce 7300 GS
- sound_card: Realtek High Definition Audio on-board
- Hard_Drive_Capacity: 2500 Gb
- Monitor/Display Make & Model: Eizo CG222W
Happens to me to (on XP). But not every time. I haven't paid enough attention to work out what is triggering it. Might be after crashes, or plugin install or both. Easy enough to reset/
F_P
F_P
