Hi there,
I currently use VSP X4 and would like you to explain the tool(s) available to guarantee a good audio balance.
If we consider the 3 types of audio - the "Feature" audio, the "Ambience" audio and the "Effect" audio (like music or narration), how can I be sure they are as relevant & accurate to each other as possible?
An example.
I record someone talking on video, VSP assumes a 100 volume level for starters. I add a background music track and again it assumes a 100 volume level. Due to the nature of the MP3 or WAV file it is always louder so I reduce the volume however, sometimes when I produce a final DVD or video file, I wish I had have lowered the music track further or increased the person talking volume because the music has overpowered a bit much.
When I select Sound Mixer; Attribute; and hover over the clip volume meter, I notice 40% is displayed.
Q1/ Is this only using 40% worth of the original volume level?
Q2/ What measures can I use in VSP x4 so that when a DVD is eventually played, there isn't a need to crank up the TV volume to hear good audio levels which then in turn introduces audio "noise"
Q3/ I notice the audio meter is coloured and I suspect that touching the red signals mean distortion. How can I use this for overall best effect?
Q4/ Should I be mixing audio levels using the "-36 to +12" slider or the clip volume in Q1?
I intend using tie-mics soon and I expect all audios I throw at my projects will need a careful balance
Thanks for your reply and please include any detailed tutorials on this as I can only find generic ones.
Phil
Correct volume levels
Re: Correct volume levels
Hi Phil
First I have to say the Video Studio is a video editor, it does its best at allowing us to manage our sound files.
My personal preference is to use the edit options and the 100% slider.
I don't use that many audio tracks, the recorded video + music and voice over.
The audio from my camera is generally used as the norm with other audio being adjusted to match.
You do need to select a normal level, even if its a sample from the library. This will ensure your pc speakers are always set to the same level.
Some things to note:-
Choosing 0% will give no sound, effectively muted.
Sound Mixer, choosing -36 (lowest sound level) does not remove all sound.
To fade In or Out I always use the fade ramps adjacent to the 100%, that way my fade does actually fade out. Set the fade duration in Preferences (F6)
If I need a middle section muting, I cut the clip using the scissors, then apply the appropriate 100% or fades to each clip.
Using the Sound Mixer will allow for rubber banding, this will add key-frames to the audio clips. I always end up with far to many. Right click the clip to reset volume will remove all key-frames, or drag individuals down as far as you can.
I always render the project to a single video file, then play to check quality, adjust the audio within the project and re-render. Smart Render should make the second render quite quick.
With the audio levels correct the final video file being used to burn to disc.
Use an audio editor to level the individual sounds prior to importing to Video Studio.
If you do not have a program try Audacity. Many on the forum have used this program.
