if i add a video file to corel studio x4 and all i do is cut out certain parts of that video file, how do export the file with the same video attibutes, the same properties as the original file? do i use the option under create video file "same as project settings" or do i use "same as first video file?" I dont want any change in the video file i want it to remain the same as the original file.
thanks
videostudio x4 exported file with same properties
Re: videostudio x4 exported file with same properties
best to use "same as first video clip" - it is possible that your project settings might not be the same as your video and if you use "same as project settings" your video will be changed
