VSP X5 screen capture not working
angelarch
processor: intel i7
Video Card: geforce GTX 560m 2GB
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: LG
Post by angelarch »
hi all-
My VideoStudio Pro X5 screen capture starts up, looks like it is about to start recording with a countdown, then pops up an error and stops.
When I saw X5 had built in screen capture I was elated, this was the feature I was most excited about. So as soon as I finished installing I tried it. . . was so disappointed that it wouldn't work. I have a 2 monitor setup, the capture window has the options to record from either window, but when I click them on neither side works. I tried just capturing applications, none work, same error. Tried making a custom window, on either monitor, big or small, still same error.
I've seen videos of it working in tutorials, so it must work somehow. I am surprised I am having a problem since I consider my system a fairly normal setup, if not better than normal.
I have a win7 64bit, G74SX, Intel i7, 16 GB ram, geforce GTX 560m 2GB, 1TB total HD.
The error popup says 'VSSCap' in the title bar, and "Prepare Record Failed!!! #0" in the body of the text.
Anyone know what that error is? Any idea if there is a fix to get this working?
Any help appreciated, thnx!
Re: VSP X5 screen capture not working
Hi angelarch
welcome to the forums
I have used the screen capture without problems, some users have had audio capture problems when capturing system audio.
The program is relatively new so not many of us have had experience in using it, certainly this issue is the first I have heard of.
I have tried a few options in trying to simulate your problem, although i do not have duel monitors.
Have you tried running the capture on a single monitor.
Corel Support may be your best option.
mkmorrison04
motherboard: Asus G74S
processor: i7 2670QM Quad Core
ram: 12 GB
Video Card: GTX 560M 3GB Ram
Hard_Drive_Capacity: 500 GB
Monitor/Display Make & Model: Asus G74S 17.3"
Post by mkmorrison04 »
I have this same issue. Screen capture does not work..
I have uploaded a print screen capture of the error that pops up "Prepare Record Failed!!! #0".
This happens regardless of what I am trying to do a screen capture on. I can select a blank area on my desktop and get the same error.
Print Screen Capture of Prepare Record Failed
Kingston
motherboard: Gateway [Acer] DX4860
processor: Intel Core i5 3rd gen. 3 GHz
ram: 8 GB
Video Card: Intel HD 2500
sound_card: Bluetooth
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Post by Kingston »
I received that error message after I accidentally unregistered qcap.dll while playing around with the Codec Tweak Tool trying to fix other things. That file is found in C:\windows\system32.
Fortunately, I have a utility, RADLIGHT FILTER MANAGER, that let me register that DLL again. In Windows XP you can also register it from a command prompt with the command REGSVR32 c:\windows\system32\qcap.dll
Of course all of this means nothing to you if qcap.dll is already registered.
e_a_g_l_e_p_i
motherboard: MSI MAG Z790 Tomahawk WiFi Gaming Motherboard
processor: Intel Core i7-12700KF Desktop Processor
ram: 32GB
Video Card: Gigabyte GeForce GTX 1060 Windforce OC 3GB GDDR5
sound_card: onboard
Hard_Drive_Capacity: 10 TB
Monitor/Display Make & Model: Dual 24 inch Samsung Monitors
Corel programs: VideoStudio Ultimate X10,PaintShopProX9
Post by e_a_g_l_e_p_i »
My screen capture works but doesn't work right, when I set my area to capture justing the drag feature and then when done and I bring it into VSP the window I captured is always off.. there is a serious bug on my version
Hope someone figures it out
Ron
Kingston
ram: 8 GB
Post by Kingston »
There are some windows you won't be able to capture, especially if video is playing in them, like when you are playing a DVD. Is that what is happening to you?
e_a_g_l_e_p_i
ram: 32GB
sound_card: onboard
That as well as non video area do not capture properly, see my problem here
http://forum.corel.com/EN/viewtopic.php ... 67#p244774
this one happens to be video but the same thing happens to other parts of my desktop or whatever screen capture I attempt
Ron
aljimenez
ram: 24GB
Video Card: AMD Radeon R9 270
sound_card: AMD High Definition Audio
Post by aljimenez »
I think that because of copyright, no video playing will be captured... Al
User for more than 10 years.
e_a_g_l_e_p_i
ram: 32GB
sound_card: onboard
Sorry Al I think you are not correct on this issue, I can capture video just not in frame
pervysage
processor: Intel Core i7 - 3610QM 2.3GHz
Video Card: nVidia GeForce 670M 3GB
Hard_Drive_Capacity: 1.5TB
Post by pervysage »
I am having the same problem, where, whenever I try to screen capture its counts down with a pop-up saying "Prepare Record Failed!!! #15" as well.
I really want to resolve this issues as its the main reason for purchasing this software.
Though i have no idea what the issue is, however, looking at everyone's computer specs, there are a few people here with ASUS mother boards or ASUS manufactured rigs...
I have a ASUS ROG G75V.
Could there be an issues with some of the per-installed software?
Just a hunch..
Morrisso
motherboard: Asus P8Z77-V LK
processor: Intel i5 3570k
Video Card: GeForce 660TI
Post by Morrisso »
I was also getting the error "Prepare Record failed #15" during screen capture use (VSP X6). I narrowed it down to the screen capture audio settings in combination with using a headset with a mic (Logitech G930).
The Corel capture auto detects my headset microphone and turns on voice in audio settings upon program startup. However, I wanted to record the capture video's audio, so I switched it to system audio. The problem is the software experiences some conflict between Voice and system audio when a mic is detected.
Long story short, I unplugged my g930 headphones (mic built in) and I am now able to use the system audio setting to capture youtube audio again. The mic must be disconnected before program startup or it auto detects it. Also, I was not able to reconnect my g930 heaphones w/mic during use, as this also caused conflict.
WRQ9
motherboard: G41M4 [MS-7592] 1.0
processor: 3.15 gigahertz Intel Core2 Duo
Video Card: NVIDIA GeForce GT 630
sound_card: NVIDIA High Definition Audio [4x]
Hard_Drive_Capacity: 8001.43 Gb
Monitor/Display Make & Model: HP 2009 [Monitor]
Post by WRQ9 »
It is not a problem w/licensing. I have the exact same symptoms in WIN 8.1. no matter what screen I try to copy (Video) I get error pop up last time #42. :(
oscarcore
Corel programs: videostudiox5
Post by oscarcore »
Hello,
I just found out that I have the same issue! and this the middle of 2014 and I don't see any fixes since 2012!
Any answers?
BarrioAV
motherboard: LENOVO MAHOBAY Win8 MM DPK IPG
processor: 2.90 gigahertz Intel Pentium G645
ram: 4GB
Video Card: NVIDIA GeForce GT 640
Monitor/Display Make & Model: HP S2031
Post by BarrioAV »
Yes, what is the deal? My VS x5 works great. About 2-3 months ago I used the screen capture for a week, no issues. Before that my computer was in storage for about a year, anyway, I counted about 10-12 screen captures total produced since I installed VSx5. Now, just as above, it stop working and I'm getting the failed #42 code.
Thinking back what has changed.....windows 8.0 to 8.1 during that time. Thinking of "rolling back" to check it. Will keep you all posted.
oscarcore
Post by oscarcore »
Now I know! VSP X5 is simply not compatible with windows 8, 8.1 and corel will not do a patch for that! http://forum.corel.com/EN/posting.php?m ... =1&t=45986#
- corel just want us to buy VSP x7 wich is compatible with 8 and 8.1 - "so there is no need to bother with them and waste time any more".http://forum.corel.com/EN/posting.php?m ... =1&t=45986#
Will just have to save some money and buy VSP x7.http://forum.corel.com/EN/posting.php?m ... =1&t=45986#
