Crop overlay images-
ct valley views
ram: 8 gb
Post by ct valley views »
Is there any way to crop a video clip in an overlay track-not just change the size of the entire image keeping it intact.
Re: Crop overlay images-
I am not sure I understand what you are trying to do.
I assume you are working with a video file, as you also mention image
Do you mean cutting the video file to reduce its length?
or resize the frame to maybe change the shape from 4:3 to 16:9
Click the video in the overlay track to select it.
the preview screen shows the frame having yellow corners, drag the corners to resize the frame.
you may see a green square this will distort the frame.
Right click the image on screen for other resize options.
Is that the type of thing you are looking for
ct valley views
ram: 8 gb
We do a Public Access program that features interview segments.
If you notice, on other network type shows there is a full screen of the host and of the guest. They also show both host & guest together in a single screen , but the images are cropped to fit-not reduced proportionally (re-sized).
Post by BrianCee »
I'm hoping the screen shot attached is the sort of thing your after
i did this in about 5 minutes by putting the two videos - one in each overlay track - choosing 'Fit to screen' for each one - then applied the 'Cropping' filter to each one. You then have to customise each filter by opening the 'options ' panel - then first use the small drop down to choose a vertical crop - then use 'Customise Filter' to set the crop to 50% and select which part - I did find it was necessary on the no.2 overlay track to remove the tick from the 'Fill Color' option or else that colour overlayed the other half. Also needed a little bit of 'manipulation' on returning to the project screen to get both bits in the right place.
A little bit of a fiddle - but once mastered easy to do.
Click on the image for a larger picture
ct valley views
ram: 8 gb
Thanks-You're right it is a bit of a fiddle, but I'll keep at it.
Bill
ct valley views
ram: 8 gb
I am able to get the cropping correct as I wanted- but when I play it as a project the video stutters, although it's in sync.
Bill Regan
ct valley views
ram: 8 gb
I rendered a 90 sec portion and the resulting MPEG is OK!?
