As a longtime BibblePro user I'm a bit confused by the way the ASP import feature works.
Previously I would use the import feature to simultaneously copy content from the memory-card to my computer and add it to the catalog.
From what I can see, in the current version of ASP it simply makes a reference in the catalog and continues to work on the files on the CF/SD card. Is there a way to tweak the ASP import function to work like the old BibblePro importer?
What's the correct procedure to import photos into the catalog? Do I have to manually copy them onto the hard disk before I start using ASP?
Importing into catalog with a copy?
salimfadhley
- System_Drive: T
- motherboard: Asus i7 board
- processor: Intel i7
- ram: 16gb
- Video Card: Nvidia 1Gb
- Hard_Drive_Capacity: 2tb
- Monitor/Display Make & Model: Asus
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Importing into catalog with a copy?
Use the download queue to copy to a specific location on the disk and import at the same time.
cheers
afx
cheers
afx
