Thank you to the Corel team for creating this fantastic photo manager and RAW processor. I have recently imported my large collection of images into ASP and begun adding keywords to them. Please let me know if I am simply misunderstanding how to use the keywords feature, but I believe I have discovered a bug. I want to select all of the images in a folder (Canon RAW CR2 and JPGs) and apply a common keyword to all of them. The folder has UNIX 770 permissions. I do the following:
- go to Thumbnail view
- make sure Multi-Image View is off
- CTRL+A or SHIFT+Click to select the desired images
- type in a comma-separated list in the Keywords box on the right column
- hit Enter
This works just fine and I see the "Save Settings" progress bar appear. This is confirmed by the console output, e.g.
Code: Select all
84101.213: "Applying 5 keyword changes with settings on 1 layers to 48 items, named: Add/Remove MetaData"Any ideas on how I can debug this further and be able to add keywords to entire groups of images, or an entire folder?
On a possibly-related note, it seems that I can only write keywords to the currently-active image (the one with the white box around it) if Multi-Image View is enabled, even if multiple images are selected.
Thanks, Andrew
