[SOLVED] Lens Calibration: Powershot G12 (Bug Reporting)
Lens Calibration for Canon PowerShot G12 doesn't work at all on RAW (not tested on Jpg)
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Lens Calibration: Powershot G12 (Bug Reporting)
What? Results wrong or no calibration data?
You might report this at the proper place, see signature.
cheers
afx
cheers
afx
The Powershot G12 is recognised as the exif data but the ASP doesn't correct at all...
I used the monkey to report the bug...
VIM
- motherboard: Dell Inc. 0G3HR7 A00
- processor: 3.60 gigahertz Intel Core i5 680
- Video Card: ATI Radeon HD 5450
- sound_card: Creative SB X-Fi
- Hard_Drive_Capacity: 10TB
- Monitor/Display Make & Model: Dell ST2410
As far as I can see, the G12 has not (yet) been calibrated. So, in fact, this is not a BUG as such
VIM: So the bug is to display PowerShot G12 in Lens Correction list...
afx
- System_Drive: N/A
It is not in the lens correction list, but the list of identified lenses (if you refer to the lenstable file that is used to display the lens name in AfterShot).PaKaL wrote:VIM: So the bug is to display PowerShot G12 in Lens Correction list...
But I personally think it is a bug to support a P&S cam without appropriate lens correction data as those itty bitty cams are rather distortion prone (one of the reasons I got the XZ-1 instead of the LX-5).
cheers
afx
Yep and the G12 is 1 year and a half old...
I'm expecting G1 X support in the next major release... as I own this one too...
The G12 and the G11 has the same lens.
Try to put this info in profile_canon:
begin lens
group: canonG12
multiplier: 4.59
menu_lens: Standard
cal_abc: 6.10 0.000000 -0.015000 0.000000
cal_abc: 6.785 0.000000 -0.015000 0.000000
cal_abc: 7.405 0.000000 -0.013000 0.000000
cal_abc: 8.108 0.000000 -0.010000 0.000000
cal_abc: 8.898 0.000000 -0.005000 0.000000
cal_abc: 9.784 0.000000 -0.003000 0.000000
cal_abc: 13.761 0.000000 -0.003000 0.000000
cal_abc: 15.673 0.000000 -0.003000 0.000000
cal_abc: 21.461 0.000000 -0.003000 0.000000
cal_abc: 30.50 0.000000 -0.003000 0.000000
end
begin camera
group: canonG12
multiplier: 4.59
menu_make: Canon
menu_model: G12
exif_make: Canon
exif_model: Canon PowerShot G12
end
begin lens
group: canonG12
multiplier: 4.59
menu_lens: Standard
end
begin camera
group: canonG12
multiplier: 4.59
menu_make: Canon
menu_model: G12
exif_make: Canon
end
I can't find profile_canon in /Library/Application Support/AfterShot Pro/ :/
Found it... And in fact there is a mistake in the original file provided by Corel...
begin camera
group: canonG10
multiplier: 4.59
menu_make: Canon
menu_model: G12
exif_make: Canon
end
begin camera
group: canonG10
multiplier: 4.59
menu_make: Canon
menu_model: G12
exif_make: Canon
end
It's working great... thanks for the help...
By the way on mac now profiles are in AfterShtop package and not in application support anymore...
