Simple Way to Rotate Images 90 Degrees?
jpmccormac
Is there a simple way to rotate JPEGs 90 degrees? The Straighten Tool in Basic Adjustments only allows 45 degrees of rotation. I know I could use ZPerspector plug-in, but are there other simpler alternatives? Or, do I need to do the rotation before opening the images in ASP? This should be a no-brainer...
"All who wander are not lost."
lathspell
Re: Simple Way to Rotate Images 90 Degrees?
Can you see two icons named "Rotate Counter Clockwise" and "Rotate Clockwise" at the top of the screen, right beside the color label and flag tools?
jpmccormac
Thanks. I've been away traveling for a week and my brain must be in jet lag.
lathspell wrote:Can you see two icons named "Rotate Counter Clockwise" and "Rotate Clockwise" at the top of the screen, right beside the color label and flag tools?
afx
- System_Drive: N/A
- Video Card: FirePro 4900
So how would the non-portable silly .NET stuff be relevant for AS?
cheers
afx
cheers
afx
