Windows needs to config PSProX
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
For some unknown reason I kept getting a message from Windows(XP) stating it had to config PSProX.Then it said it could not do so because the file is on the disc and not available.I inserted the disc which got rid of the messages.Now I have lost the ability to do a screen capture,after right clicking the screen, unusually, I have to drag over the target area and a blue area is highlighted but this does not transfer to PSPro for further use.To do a screen capture before this, after right clicking,I could draw a marquee around the target area which then trnasferred to PSPro automatically.Help please!
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Corel programs: PaintShop Pro X9
Re: Windows needs to config PSProX
I use the Windows Screen capture instead of the PSP version.Kenneth Veal wrote:For some unknown reason I kept getting a message from Windows(XP) stating it had to config PSProX.Then it said it could not do so because the file is on the disc and not available.I inserted the disc which got rid of the messages.Now I have lost the ability to do a screen capture,after right clicking the screen, unusually, I have to drag over the target area and a blue area is highlighted but this does not transfer to PSPro for further use.To do a screen capture before this, after right clicking,I could draw a marquee around the target area which then trnasferred to PSPro automatically.Help please!
I hit the Print Screen key, which captures everything on the desktop/website etc, then right-click in the PSP workspace>Paste as a New Image.
If I only want to capture the active window, like a message box or something, I hold the Alt key, hit the Print Screen key and paste into PSP as described.
Is that what you had in mind?
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
Ken Veal
- ram: 32 GB
Thanks for that workround Joelle,print screen and R/C workspace then save as new image worked a treat but pressing alt + print screen did not make any difference.Have you any more details on that method.................Ken
Joelle
- ram: 16 GB RAM
Kenneth Veal wrote:Thanks for that workround Joelle,print screen and R/C workspace then save as new image worked a treat but pressing alt + print screen did not make any difference.Have you any more details on that method.................Ken
Try this:
Open any image, apply anything, Enhance Photo>Smart Photo Fix will do.
When Smart Photo Fix is open, hit the Alt Key + Print Screen.
Close the box and then right-click in the Workspace>Paste as New Image.
This should result in a copy of the Smart Photo Fix box.
Using the Alt Key will tell Print Screen to only copy the active image.
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
Ken Veal
- ram: 32 GB
Thanks for all the info!
