ASP wont save or export any of my edits
jost
operating_system: Linux
System_Drive: N/A
Post by jost »
Im running on the latest Ubuntu Linux, in 64BIT mode on an AMD based machine.
I understand how nondestructive editing works, etc.
However, after im done editing/tweaking a photo in ASP, I wish to export or save it externally with all the edits/tweaks applied.
Cant seem to do it! What am I missing?
Every time I do a file save as, or send files to a selected batch, ASP always exports a completely un- retouched JPG version of the RAW files. All of my edits are stripped during save or export.
HELP. Love ASP... but this is driving me mad.
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: ASP wont save or export any of my edits
Post by afx »
Sounds quite weird.
Can you post a screenshot of your queue and the XMP file for a sample image?
cheers
afx
jost
System_Drive: N/A
Post by jost »
Not sure what you mean by "screenshot of your queue".
You want the XMP file of an exported image?
afx wrote:Sounds quite weird.
cheers
afx
spoilerhead
System_Drive: N/A
Hard_Drive_Capacity: 13.5TB
Post by spoilerhead »
maybe you somehow messed up file permissions? (i.e. your user got no write permissions to the xmp files)
my ASP Plugins - donation button ( send beer! :) )
linux,7d, glass and a huge mug of coffee.
If you got any immediate problems with my plugins, don't by shy on contact me on GoogleTalk.
jost
System_Drive: N/A
Post by jost »
spoilerhead wrote:maybe you somehow messed up file permissions? (i.e. your user got no write permissions to the xmp files)
Thought of that.... running ASP as root on linux so it has full power to over write any file anywhere.
No dice.
At least now I know its not supposed to work like this. I figured there was some trick to saving a file I wasnt aware of.
May need to do a full re-install maybe... and try again
afx
System_Drive: N/A
Post by afx »
jost wrote:running ASP as root on linux
You like to live dangerously, do you?
cheers
afx
jost
System_Drive: N/A
Post by jost »
While debugging an issue, ill try anything. Prefer not to run as root, but that removes all the permission variables from the equation until I figure out what the problem is
Really wish this forum wouldnt require moderation for every single post of mine :(
cheers
afx
afx
System_Drive: N/A
Post by afx »
jost wrote:While debugging an issue, ill try anything.
Fair game, I would have written it differently then though. It sounded as like you do this by default.
I think that will stop after a few posts.
cheers
afx
ogrizzo
operating_system: Mac
System_Drive: Q
processor: 2.8 Ghz Intel Core i7
ram: 8 GB
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Integrated Apple iMac 27"
Post by ogrizzo »
jost wrote:While debugging an issue, ill try anything. Prefer not to run as root, but that removes all the permission variables from the equation until I figure out what the problem is
Not if the directories are remote mounted, though. Did you try to run ASP through strace? that should show all error messages the C library gets back from the file system.
Ottavio
michaeld
System_Drive: N/A
Post by michaeld »
jost wrote:Every time I do a file save as, or send files to a selected batch, ASP always exports a completely un- retouched JPG version of the RAW files. All of my edits are stripped during save or export.
Just for reference, I'm seeing a similar behaviour that for some images my changes get lost. "Prefferably" when I have 2 versions of a file with one version is cropped and the other isn't, I get 2 uncropped versions.
This is in filesystem mode, but I haven't tracked that down further.
Maybe this has something to do with the problem that sometimes the wrong file (version) is deleted? (Don't have the reference.)
Bye,
Michael
andreas
System_Drive: X
motherboard: Asus in Workstation and Dell XPS Notebook
processor: i7-980 and i7-2720QM
ram: 12GB - 8GB
Video Card: ATI FireGL
sound_card: on board
Hard_Drive_Capacity: 4.5TB Rd10
Monitor/Display Make & Model: Samsung Syncmaster 2343sw
Post by andreas »
Jost,
you have tried after moving your cache folder and rootdb out of the way? Both are located in your user asp folder.
Andreas
Linux - not Windows
jknights
motherboard: Apple
processor: Intel 3.08GHz Dual processor Quad Core
ram: 24GB
Video Card: ATI Radeon X1600
sound_card: Intel HDA
Hard_Drive_Capacity: 6TB
Monitor/Display Make & Model: Apple Display
Post by jknights »
I think that what you are missing is that you need to go into the Output tab and send file to a queue.
If you do this then you get asked where you want to save the file(s) and the image is saved with all your changes in the desired directory.
It is not as simple as SaveAs but a send to an Output queue that sends it to a Batch that processes it as a JPG (full size)/TIFF/JPG (small) or whatever batches you have created.
Initially this seems slower but once everything is set up it actually makes sense!
Still learning after all these years!
VIM
operating_system: Windows 8.1
motherboard: Dell Inc. 0G3HR7 A00
processor: 3.60 gigahertz Intel Core i5 680
Video Card: ATI Radeon HD 5450
sound_card: Creative SB X-Fi
Hard_Drive_Capacity: 10TB
Monitor/Display Make & Model: Dell ST2410
Post by VIM »
In my early Bibble days, I exported my JPG's from Bibble into the same folder/directory as my RAW...
But the original JPG file (I used to shoot RAW+JPG :!: ) was already there. Which I indeed saw as unedited as it was not replaced by the export from Bibble :oops: :oops: :oops: .
Hope your problem is not something similar?
peter2012
motherboard: Do not know
processor: Intel Core i5-2430M 2.4GHz
ram: 8Gb
Video Card: Do not know
sound_card: Do not know
Hard_Drive_Capacity: 500Gb
Monitor/Display Make & Model: Acer laptop
Post by peter2012 »
Hello
Did anyone ever get to the bottom of this?
I have a similar problem.
I make the usual non-destructive amendments to the RAW to produce a clear, bright image.
The I batch process to a JPEG. JPEG comes out beautifully, just the same as in ASP. This is as viewed in the standand Windows 7 photo viewer which opens when you open an image file.
Then I upload to my website. The uploaded version is horriby murky/not bright, as though all the ASP non-destructive edits have been stripped out! This does not happen with any other JPEGS, just the ones created in ASP. I am wondering whether there is some kind of JPEG sidecar file (never heard of one before), the settings from which show when I view on my computer but do not show when I upload just the JPEG to my website. Seems unlikely but this is the only thing I can think of other than maybe there is something about ASP JPEGS that gets mangled in standard ISP image-crushing sofware like ImageMagick.
If anyone can help I'd be grateful.
Love ASP by the way - great functionality/workflow - I just need to resolve this issue.
Peter
afx
System_Drive: N/A
Post by afx »
peter2012 wrote:Then I upload to my website. The uploaded version is horriby murky/not bright, as though all the ASP non-destructive edits have been stripped out! This does not happen with any other JPEGS, just the ones created in ASP.
Please post an example, otherwise the discussion is quite useless.
cheers
afx
