Whenever I try to open jpeg files larger than 2MB PSP 4 crashes.
The files open fine in PSP 3
Aby ideas?
PSP X4 Ult Crashes when opening large jpeg file
LindaSue
- motherboard: Gigabyte
- processor: 2.71GHz AMD Athlon II X2 215 processor
- ram: 3 GB
- sound_card: Realtek AC97 Audio [onboard]
- Hard_Drive_Capacity: 1320 GB
- Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
- Corel programs: Paint Shop Pro X2, X4, X6
Re: PSP X4 Ult Crashes when opening large jpeg file
Does it happen every time? I just created a 12 MB JPG image and had no trouble at all opening it in X4. Maybe you've got a corrupted file.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
You may want to check if this happens on all the large files that you are opening or just one file. You can also try reseting your workspace, since that can also be the problem.
You can do that by pressing and holding down the SHIFT key then double-click on the PSP icon then when you received the message "DO YOU WAN TO RESTORE PAINTSHOP Pro TO ITS DEFAULT STATE?" just click OK.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
Grafula
- motherboard: Asus Laptop G50V Series
- processor: Intel Duo T 9400
- ram: 4GB
- Video Card: Nvidea Geforce 9800M GS 512MB
- Hard_Drive_Capacity: 320GB
- Monitor/Display Make & Model: 15.4" WSXGA+ Asus Laptop
It happens every time.
I did reset the the workspace.
It happens with every jpeg file larger than about 2.5 MB
For sure not a corrupted file.
I can open the same file in PSP 3 without problem.
Thanks.
Thanks.
brucet
I work with 92meg tiffs and save a copy as a jpeg that is about 5meg everytime as a backup for other jobs. Never have a size issue.
Regards
Regards
