X5 plugin install prob
Music-amg
Post by Music-amg »
Everything installed properly, EXCEPT, Boris. Before I bug Corel support, I'd ask here. Boris installed fine in X4, just not showing up in X5. So I think, I may have missed it in the FX previews, but, I am pretty sure it is not there. At least, it is not showing up as it did in X4. Any Ideas? I have X5, X4 ultimate..
Re: X5 plugin install prob
Have a look at this: http://corel.force.com/index/articles/e ... 4-Ultimate It may also work with X5.
Music-amg
Post by Music-amg »
Apparently, you can only have one version of Boris on the Windows XP computer at a time. X4 ships with version 5.3. X5 ships with 5.4. If detected, Boris will not install over the older version. You have to uninstall the older version and install the newer version. While I was waiting on info from Corel Support, all I did was copy the vft file from X4 to X5 plugin directory. (filename "Graffiti5.vft"). Which works.. Just have not recieved "official word" from Corel on reinstalling Boris 5.4. (5.3 shows up in unistall in control panel add/remove) Probably will be 1) uninstalling Boris 5.3, 2) re-installing X5, 3) copying Boris 5.4 vft to plugin folder of X4) but, havn't tried the solution yet.
"edit"
This is from Corel...
"Thank you for contacting Corel Customer Support.
Please be advised that Boris Graffiti 5.4 is a third-party software bundled to VideoStudio Pro X5 Ultimate; if you have VideoStudio Pro X4 Ultimate installed on your computer which includes Boris Graffiti 5.3, you will need to uninstall first Boris Graffiti 5.3 before installing Boris Graffiti 5.4. After wards, you should be able to access Boris Graffiti 5.4, in VideoStudio Pro X5.
The serial number for Boris Graffiti 5.4 is already provided on the serial number field in the installation window of Boris Graffiti 5.4; hence, there is no need for you to enter a serial key.
Please do not hesitate to contact us with any further questions.
Ivan
Corel Customer Support Services"
greatphotos
Post by greatphotos »
My issue with Grafiti o X5 is it doesn't like the license key that comes up automatically. Help button says second character should be an N and I have and X so I changed it still didn't get past license screen.
I do have X4 installed but this doesn't sound like I am at the point where have an older plugin that needs removed.
Roberto
motherboard: GigaByte MA790XT-UD4P
processor: AMD PhenomII X4 Black Edition
ram: 6 GB
Video Card: Sapphire HD5670_1G
sound_card: Soundblster Platinum XFi_SB4860
Hard_Drive_Capacity: 500 GB
Monitor/Display Make & Model: AEC 24"
Post by Roberto »
I have a question: does X5 still have a limitation for the maximum number of plug-ins that can be installed as Video FX or Transitions ?
Peter100
motherboard: Asus P7P55D-E
processor: i5 750
Video Card: ATI Radeon HD 5570
sound_card: MB integrated
Monitor/Display Make & Model: Samsung SyncMaster 2494
Post by Peter100 »
Does the Windows 7 have the same problem as XP with both coexisting versions of Boris Graffiti (i.e. 5.3 and 5.4) being installed?
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Post by teknisyan »
Hello Music-amg,
Have you tried following the steps that Ken gave you? Was the problem resolved?
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
Budda_357
motherboard: Gigabyte GA-Z68XP-UD4 V1.3
processor: I7-2600K OC 4.6 Ghz
Video Card: Asus GTX660Ti 2GB OC Edition
sound_card: On Board 7.1 HD Audio
Hard_Drive_Capacity: 11.240 TB
Monitor/Display Make & Model: Samsung S23A950 23in 120Hz 3D Widescreen LED Monit
Post by Budda_357 »
Hi Guys
I purchased the VSX5 Upgrade last week I too have the same problem and this is a new machine with no previous Corel installs.
When you select the Boris plugin to install the window opens input the info yarda yarda then shows the directory path as C; Program Files (X86)/ Boris FX Inc go through the motions hit install the Corel Boris installer window opens at bottom right showing a progress bar that does not move but the strange thing is the main window is now displaying the VS X5 programs directory path for the install of the Boris Program which must be the installer that is supplied with the program would have thought the first path displayed so you can change directory would have been the VS X5 directory.
Changing the path in the beginning to the same one that shows after the install progress bar opens does not resolve the issue.
In addition windows task manager shows the installer is running OK the Boris exe process is only taking 1% cpu tried giving it higher priority did nothing
So have fired off a support request to Corel for an answer.
Read somewhere a Corels response of Boris "being 3rd party" not my problem as Corel supplied as part of the purchase so they can't just wash their hands it has to be a problem with the installer so who created the installer for 3rd party stuff Corel or Boris FX Inc.
Cheers From Down Under
Budda [sic]
DVD Movie Factory: DMF4SE, V5 Plus, V6 Plus, V7 Pro
Video Studio: V10, V11.5, VX2, VX4, VX5, VX7 (Ultimate Versions)
Photo Impact: VX3
Paint Shop Pro: PSPX3, PSPX5, PSPX7 (Ultimate Versions)
Painter Essentials: V3, V4
Just to let you know -- I have removed your other post which covers this exact question, so as to avoid confusion.
Budda_357
Post by Budda_357 »
Hi, Ken
Sorry I did a quick browse before I posted and missed this post sorry.
Budda [sic]
Photo Impact: VX3
Budda_357
Post by Budda_357 »
Hi Guys
Corels response was the safe mode install which had tried before I sent the email.
But finally got the plugin to install :) seemed maybe be a strange glitch with their installer and W7 64bit.
Cheers
Budda [sic]
Photo Impact: VX3
Neil-G
motherboard: HP Z800 Workstation
processor: Intel Xeon
ram: 72gb
Video Card: Nvidia GeForce GTX 1060 6gb
Hard_Drive_Capacity: 2 tb
Monitor/Display Make & Model: Sony KDL-22BX200
Corel programs: VideoStudio X4 Ultimate
Post by Neil-G »
Music-amg wrote: Fri Mar 16, 2012 9:21 am Everything installed properly, EXCEPT, Boris. Before I bug Corel support, I'd ask here. Boris installed fine in X4, just not showing up in X5. So I think, I may have missed it in the FX previews, but, I am pretty sure it is not there. At least, it is not showing up as it did in X4. Any Ideas? I have X5, X4 ultimate..
I have just got the boxed X4 Ultimate at a very good price, but am having a terrible time getting Boris Graffiti 5.3 to show up in the FX library. Please can you help?
Neil-G
ram: 72gb
Post by Neil-G »
Just to add that I have X4 Ultimate on a Windows 10 PC so it might be a bridge too far!
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
Neil-G wrote: Just to add that I have X4 Ultimate on a Windows 10 PC
You've resurrected a thread over ten years ago about X5. Note that the Corel VideoStudio Pro X4 System Requirements are "Microsoft® Windows® 7, Windows Vista® or Windows® XP with latest service packs installed (32-bit or 64-bit editions)". That said, I had no problem years ago running X4 on Win10.
In any event, did you follow the instructions in "The Mercalli or Boris Graffiti plugins are not installed in VideoStudio Pro X4 Ultimate" (https://kb.corel.com/en/127721)?
tletter
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
"I have just got the boxed X4 Ultimate at a very good price", was it below 1.63£ ?
Panasonic X900m, VXF1
