[plugin] zFrame 3.13 produces unwanted pixels
AfterShot Pro Plugins
deifl
operating_system: Linux
System_Drive: Z
motherboard: Belarc Advisor do not work on my systems
processor: Belarc Advisor do not work on my systems
ram: avg gt 4GB
Video Card: Belarc Advisor do not work on my systems
sound_card: availible
Hard_Drive_Capacity: avg gt 2TB
Monitor/Display Make & Model: 10" to 24" (12.5" and 24" IPS)
Post by deifl »
Hello,
I use zFrame (in conjunction with zText) to annotate pictures at the bottom. Worked fine for a while, but after a zFrame update a line of unwanted pixels appear at the right side of the picture. There is a line in the frame-color of a few pixels.
The 2 attached pictures (before and after) show this (I hope that I done right so they show up).
Here the used preset (only zFrame):
Code: Select all
<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP Core 4.4.0">
 <rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
  <rdf:Description rdf:about=""
    xmlns:bib="http://www.bibblelabs.com/BibbleToplevel/5.0/"
    xmlns:bset="http://www.bibblelabs.com/BibbleSettings/5.0/"
    xmlns:blay="http://www.bibblelabs.com/BibbleLayers/5.0/"
    xmlns:bopt="http://www.bibblelabs.com/BibbleOpt/5.0/">
   <bib:settings>
    <rdf:Description
     bset:settingsVersion="66"
     bset:respectsTransform="True"
     bset:curLayer="0">
    <bset:layers>
     <rdf:Seq>
      <rdf:li>
       <rdf:Description
        blay:layerId="0"
        blay:layerPos="0"
        blay:name=""
        blay:enabled="True">
       <blay:options
        bopt:hasSettings="true"
        bopt:zFramePlug.zframeSize1="2"
        bopt:zFramePlug.zframeColor1="-1"
        bopt:zFramePlug.zframeEnable="true"
        bopt:zFramePlug.zframeEnable1="true"
        bopt:zFramePlug.zframeRatio1="-100"
        bopt:zFramePlug.yPos1="-100"/>
       </rdf:Description>
      </rdf:li>
     </rdf:Seq>
    </bset:layers>
    </rdf:Description>
   </bib:settings>
  </rdf:Description>
 </rdf:RDF>
</x:xmpmeta>
Greetings
[Sorry for bad english]
zFrame Settings
zFrame Settings
After applying zFrame
Before applying zFrame
tintin
processor: Ryzen R5 3600X
Re: [plugin] zFrame 3.13 produces unwanted pixels
Post by tintin »
the pictures you attached... are them screenshots or ASP-outputs?
can you please post the old and the new version you tried before and after your update?
br,
tintin
my plugins on the official plugins homepage
If you find my plugins helpful, please make a donation to support further developments - just click here, thank you!
deifl
System_Drive: Z
ram: avg gt 4GB
Post by deifl »
the before-picture is just a black filled jpg. The other is the ASP-output after activating the attached preset. After running through zFrame there is a 1px wide border at the right side.
Any hint where I can download a older version of zFrame to show you the output
Greetings
tintin
Post by tintin »
hello,
deifl wrote:Any hint where I can download a older version of zFrame to show you the output
no, sorry i don't. the actual plugin packages are available on the ASP-plugin-site directly. there is no possibility to get older versions.
do you still know the version number that you had before this effect was available?
if you still think you need an older version you can PM me with an eMail-address, so i might send a former version - but also then you'd need to tell me the version number you'd need... :?
br,
tintin
