Ulead 11 Wont import AVI file
thefakefatshady
Hi there,
Sorry if this post is answered somewhere else (Ive tried looking and cant find it)
I'm running Ulead Video Studio 11, and I have AVI files I have downloaded from the internet. When I try to import them into Ulead I get the following message - ''(FILENAME) is not accessible'' followed by ''These files cannot be added to this project. These files may be of unknown file format, the computer does not have enough memory or the file is copyright protected''
If I right click the files, this is the info I get -
624x352 Pixels
Audio
142kbps
MPEG Layer 3
Video
23 Frames Per Second
1117kbps
Am I missing some form of codec for this particular AVI ??
Thanks in advance
Mick
624x352 Pixels
Audio
142kbps
MPEG Layer 3
Video
1117kbps
Thanks in advance
Mick
canuck
Re: Ulead 11 Wont import AVI file
Could you perhaps post a link to one of those avi files? Some of us could download it and see if we have the same problems.
cAlmost undoubtedly it is a codec question. Unfortunately, the information you provided on its properties (from Windows Explorer?) does not give us any information as to exactly which codec might have been used. You see, there are over 800 different file formats which call themselves avi since that is only a wrapper format. If you could look for a freeware program called GSpot, it will give more information as to the exact codec used...
thefakefatshady
Thanks! Ah Ive just double checked and its an xvid (BDRip). Am I ok to post links to files here???
yes it's OK to post links so we can help you
thefakefatshady
Hi Ken thanks for the GSpot tip
I ran it and this is what I got
Audio - 0x0055 MPEG-1 Layer 3
Video - XviD ISO MPEG-4 - Codec(s) are NOT Installed
OK so I need to get an Xvid codec?
thefakefatshady
Guys I installed an Xvid codec and now the file loads up in Ulead. Id like to say THANK YOU very much for the advice!!
Mick
Mick
thefakefatshady
Ohh no!
Problem again! The audio is out of sync when I load the files up. The audio comes about 2 seconds before the event.
thefakefatshady
The files are perfectly in sync when played with VLC or whatever, but loaded up in Ulead the audio is way out
... And if you render the project to some other format in VS, is the sync still out? If so, then disable SmartRender...
thefakefatshady
Hi Ken,
Yeah I mixed it to MPEG 2 and the sync was still out. I kinda think Smart Render may already be disabled. I clicked File/Preferences and on the Smart Proxy tab the 'Enable Smart Proxy' box is unchecked.
thefakefatshady
Im guessing Smart Proxy and Smart Render are the same thing?
No. SmartProxy is essentially to make it easier to process high definition video on less powerful computers.
SmartRender is for only rendering parts of a project to which edits have been made. But it is for rendering from one format to the same format. In your case you are going from one format to the other, so SmartRender doesn't apply there anyway...
thefakefatshady
Cheers Ken, how do I disable Smart Render?
As I said, it does not apply in your case since you are rendering from one format to a different one. But you normally disable it when you go to Share > Create Video File and choose the format. Then in the dialogue box which opens where you give your new file a name, click on the Options button. SmartRender is listed in the new window which appears. Untick it.
