Rename, Reorder, and Customize Tabs (Howto)
Tips, Tricks, and Results
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: Rename, Reorder, and Customize Tabs (Howto)
Post by afx »
grooveman wrote: Anyone else finding they have a capital "C" here?
Yes, that made me realize I had an old version (1.0.1) installed, the current version is 1.1.0 with a lower case in the identifier.
cheers
afx
Ianr
Monitor/Display Make & Model: Dell 30
Post by Ianr »
Bought a new Gaming keyboard (G100) and would so love to be able to set it up to do my favorite Actions. Unfortunately Mouse click when selecting an action to record does not work as is. Would seem that the data in the .xmp file would work. Anyone have experience with such with a gaming keyboard ?
Love the new layout .. so quick now to just select the tab category one wants to deal with.
Thanks, ianr
ormdig
motherboard: Asus Sabertooth X58
processor: Intel i7-950 3.72Gh
ram: 24Gb
Video Card: Nvidia GeForce 460
sound_card: Realtek HD audio
Hard_Drive_Capacity: 4.5 Tb
Monitor/Display Make & Model: HP LP2475w, HP LP 2065
Post by ormdig »
afx wrote: Yes, that made me realize I had an old version (1.0.1) installed, the current version is 1.1.0 with a lower case in the identifier.
cheers
afx
How do you update Vigne to 1.1.0? Thank you.
grooveman
System_Drive: N/A
Post by grooveman »
Go here. Assuming you have already registered, you will need to login (if not, then register), then click the link that refers to the "special gift". Download it, double click it or open AFS pro, and click "File", then "Install Plugin". It will prompt you, then click "update", restart, and you should be golden.
Oh yes, and change that captial "C" in Corel in your customToolsUI.txt to a lower case "c".
ormdig
ram: 24Gb
Post by ormdig »
Thank you grooveman, I was going to the Plug In site without logging in and it didn't show the version number. it just said "free with ASP". As soon as I logged in it offered the upgrade.
kaymann
motherboard: ASUS P8P67 PRO REV 3.1
processor: Intel i-7 6800K
ram: 32 GB
Video Card: NVidia GeForce RTX 2060
sound_card: Onboard
Hard_Drive_Capacity: 3.5 T
Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
Post by kaymann »
With the help of everybody here I customized my tabs. My intent was to either get all plugins on one tab or ensure I did not have to scroll through any one of the tabs. I hate the way the wheel would jump tabs. I also found most of the plugin names insteresting but not indicative of their purpose. So ultimately I made sure the tab described the purpose. I also had to get creative so no one tab had hidden (scroll down to find) plugins at my screen resolution and window sizing. Also I believe I have every plugin that is currently available for ASP (AFAIK) assigned to a custom tab.
I found the easiest way to find out the "name" of a plugin was to go to System Info. I copied the plugin info into a text file and then could copy and paste into my "customToolsUI.txt" as it was built. Some interesting discoveries:
*Tab order in the file, dictates tab order in ASP.
*Plugin order in the file, dictates plugin order in ASP.
*Extra lines in the file could help in organizing your file with no harm.
*Any plugin not specified in the file landed in the Plugin1 tab This made it easy locate the unassigned plugins one at a time and assign them to my customized tabs.
*If you use my or anyone elses file and do not have one of plugins ASP will ignore that line in your file without consequence.
Just for reference YMMV:
Metadata, DAT, Metadata.ui
Metadata, DAT, de.schrell.asGPS
Keywords, KW, Keywords.ui
Keywords, KW, Keywords/KeywordSets.ui
Presets, PRE, Presets.ui
Standard, STD, Histogram.ui
Standard, STD, com.roland65.AutoLevels
Standard, STD, BasicTools.ui
Standard, STD, Advanced/Exposure.ui
Layers, LRS, net.sadman.aftershot.texa
Color, CLR, Advanced/Curves.ui
Color, CLR, SelectiveColor/SelectiveColorWidget.ui
Color, CLR, ColorBalance.ui
Color, CLR, Advanced/WhiteBalance.ui
Color, CLR, Advanced/ColorManagement.ui
Tone, TN, Advanced/Tone.ui
Tone, TN, com.roland65.SContrast
Tone, TN, com.ferdinand-paris.bez
Tone, TN, MB_Asp_Lightroom
Noise, NS, Advanced/RAWNoise.ui
Noise, NS, sph.waveletdenoise
Noise, NS, NoiseNinjaStandard.ui
Noise, NS, sph.grain
Sharpen, SRP, Advanced/Sharpen.ui
Sharpen, SRP, sph.waveletsharpen
Sharpen, SRP, com.roland65.USM
Sharpen, SRP, tin.tin.zSoften
Fix, FX, name.deindl.mdRedEyes
Fix, FX, MirrorInvert.ui
Fix, FX, tin.tin.zPerspector
Fix, FX, com.kbarni.grid
Lens, LNS, CAQuest
Lens, LNS, Advanced/LensCorrection.ui
B+W, BW, com.corel.BlackAndWhite
B+W, BW, com.ferdinand-paris.mix3
B+W, BW, sph.SiliconBonk
Equalizer, EQZR, com.kbarni.equalizer
Equalizer, EQZR, sph.FatToni
Equalizer, EQZR, de.olumix.rgbchannelplugin
Mixer, MXR, tin.tin.zchannelmixer
Mixer, MXR, com.SMP.Nuance
Mixer, MXR, Mathbox
Effects, EFCT, com.corel.vigne
Effects, EFCT, com.SMP.Nostalgia
Effects, EFCT, com.kbarni.zone
Finish, FIN, tin.tin.zText
Finish, FIN, tin.tin.zShadow
Finish, FIN, tin.tin.zFrame
grooveman
System_Drive: N/A
Post by grooveman »
Hmm... looks like I've been missing Sadman's plugins. Texa in particular looks very intersting, but hard to classify. Because my laptop screen is small, I want to keep my tabs to a minimum, and I can't afford to put only one plugin on a tab, so I think I'll put it on Finish2... I find scrolling for tabs much more cumbersome than scrolling within tabs. I just keep the most frequently used tools toward the top to minimize scrolling within tabs...
Updated.
Thanks.
G
lundbech
System_Drive: N/A
motherboard: HAL 9000
Post by lundbech »
Is there a way to resize(enlarge) the Presets Window, like it was possible in Bibble?
grooveman
System_Drive: N/A
Post by grooveman »
lundbech wrote:Is there a way to resize(enlarge) the Presets Window, like it was possible in Bibble?
Hmm.... Not that I'm aware of... If AFX hasn't chimed in yet, I'd bet there isn't. ;)
You might try asking this question on the bibble forums if you get no joy here... It says bibble, but there is still a large group of people posting there, even for ASP.
grooveman
System_Drive: N/A
Post by grooveman »
Updated to add the wonderful new plugin by Andreas, asGPS.
After so many additions (and some plugins violating easy classification) I feel my tab organization is starting to break-down, so I will reorg and respost soon, but for now, the current setup has asGPS under "Metadata". I guess it comes down to what bothers you most: The number of tabs (and scrolling for them) or scrolling within tabs, of the two, I hate the former most....
G
claudermilk
Post by claudermilk »
I don't believe there is. I've tried a few times with no luck. Seems like the sizes of hte tool panels are locked.
Bibble transplant
nyukuri
ram: 4GB
Hard_Drive_Capacity: 500GB
where to find the info for customToolsUI
Post by nyukuri »
With the help of you guys, I also organized my tools and plugins as it suits me.
But now I have two new plugins in "Plugins 1" and want to classify them as well. Where can I find (in general) the info needed for the customToolsUI for any new plugin I come across?
PS: I found the solution to my question! Thank you anyway :)
afx
System_Drive: N/A
Post by afx »
Help-> System Info.
cheers
afx
nyukuri
ram: 4GB
where to find these plugins: ....?
Post by nyukuri »
I only know the official plugin site of ASP
But where can I find the following plugins:
- net.sadman.aftershot.texa
- net.sadman.aftershot.typewriter
- USM (sharpening)
- com.kbarni.grid
- de.olumix.rgbchannelplugin
- com.nexe.nuance
THANK YOU guys!
grooveman
System_Drive: N/A
Post by grooveman »
Keep in mind that Aftershot, only a short while ago, was known as Bibble (before the Corel Buy-out and some time after even), so some of these are still posted on the Bibble forum under threads started some time ago. It will be nice when all of these can be found in one central location (something that is slowly coalescing), but until then you have to search the plugin page, the aftershot forum and the bibble forums (which each have plugin topics)
Texa
Typewriter
USM
Grid
Mix
Nuance
Bear in mind that some of these links are moving targets, and that some authors are good at keeping the download on the first or second post, while others have multiple links throughout the thread (the last usually being the most current). Others choose to host the plugins on their own servers... so while these links are good today, they may or may not be a month or two from now.
Good luck.
G
