Rename, Reorder, and Customize Tabs (Howto)
--Look to the 4th post in this thread for the solution--
Original post below:
I have read through the manual, and have not found a solutions for this. I'm wondering if there is a way I can change the order tool blocks on my tabs, you know, all the tools on the "Standard", "Color", "Tone" tabs, etc. all the way through the plugins. Especially with the plugin tabs, I'd like to organize the plugins in a way that makes sense to me and to my work flow. They are all jumbled in there, pretty much willy-nilly.
I know there is a collaps and pin option (pretty useless if you ask me) -- that isn't what I want. I just want to reorder them within a tab, and be ablt to move them from one tab to another. It would be nice if I could do this by drag and drop, but even if I have to hack an .inf or config file I'd take it.
Thanks.
-G
Thanks.
-G
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
Re: Reordering tabs and their contents
As I understand it, you can use the same interface customisation techniques in ASP as you could in B5. You can read about that here. I am not sure that this will achieve all the customisation you require, but at least it will get all the tools you always want onto the same tab and in the order in which you use them.
HTH
Mike
HTH
Mike
Dude. You are awesome.
Thanks!
G
Thanks!
G
SOLUTION:
Ok,
Thanks to Mike for pointing me in the right direction, and of course to AFX, for posting these instructions in the first place. The instructions were for bibble, so I had to redo everything from scratch, but, after some effort, I was able to find all the ui blocks (cuz you have to recreate the entire menu list, you can't just do some of it, or the items you miss simply won't be there). I also was able to find the identifier strings for all the plugins for ASP to date.
So, I am including the fruits of my labor for the last few hours below, in case someone else wants to do this with ASP. Just copy the code block below and save to a file called customToolsUI.txt. Place it in the ~/.AfterShotPro directory or into c:\users\username\appdata\local\corel\aftershotpro -- and it should work. Of course, you will have the tabs as I set them, but you can feel free to change tab names, and cut & paste each line (just watch for typos). At least you won't be hunting for plugin identifiers and ui blocks. It will still save you a lot of time.
Enjoy!
-G
Ok,
Enjoy!
-G
Code: Select all
Basic, STD, Histogram.ui
Basic, STD, com.roland65.AutoLevels
Basic, STD, BasicTools.ui
Basic, STD, Presets.ui
Color, Clr, Advanced/Curves.ui
Color, Clr, SelectiveColor/SelectiveColorWidget.ui
Color, Clr, ColorBalance.ui
Color, Clr, tin.tin.zchannelmixer
Color, Clr, com.SMP.Nuance
Color, Clr, Advanced/WhiteBalance.ui
Color, Clr, Advanced/ColorManagement.ui
Tone, Tone, Advanced/Tone.ui
Tone, Tone, Advanced/Exposure.ui
Tone, Tone, com.ferdinand-paris.bez
Tone, Tone, sph.FatToni
Noise, NZ, Advanced/RAWNoise.ui
Noise, NZ, sph.waveletdenoise
Noise, NZ, NoiseNinjaStandard.ui
Noise, NZ, Advanced/NoiseNinjaRegistered.ui
Noise, NZ, sph.grain
Sharp, SHP, Advanced/Sharpen.ui
Sharp, SHP, sph.waveletsharpen
Sharp, SHP, USM
Sharp, SHP, tin.tin.zSoften
Correct, CRCT, name.deindl.mdRedEyes
Correct, CRCT, MirrorInvert.ui
Correct, CRCT, Advanced/LensCorrection.ui
Correct, CRCT, tin.tin.zPerspector
Correct, CRCT, com.kbarni.grid
Correct, CRCT, CAQuest
B+W, B+W, com.kbarni.equalizer
B+W, B+W, sph.SiliconBonk
B+W, B+W, com.ferdinand-paris.mix3
B+W, B+W, com.corel.BlackAndWhite
B+W, B+W, com.nexe.nuance
Finish1, FNSH1, com.corel.vigne
Finish1, FNSH1, com.SMP.Nostalgia
Finish2, FNSH2, net.sadman.aftershot.texa
Finish2, FNSH2, tin.tin.zFrame
Finish2, FNSH2, tin.tin.zText
Finish2, FNSH2, net.sadman.aftershot.typewriter
Finish2, FNSH2, tin.tin.zShadow
Metadata, Mdata, Metadata.ui
Metadata, Mdata, Keywords.ui
Metadata, Mdata, Keywords/KeywordSets.ui
Metadata, Mdata, de.schrell.asGPS
Re: [Solved]Reordering tabs and their contents
Just added entries for Ferdinand's Bez and Mix3.
Just added entries for zSoften and mdRedEye by tin tin.
Also added USM and caQuest by Andrew Johnston
Ianr
- Monitor/Display Make & Model: Dell 30
Thanks heaps for this .... just placed the text file in user folder location for it to work for me.
Cannot find the TinTin redeye plugin anywhere though .. maybe its coming
Nice way you have laid out the tools ... Thought has gone into this. Ianr
Paul Wossidlo
- processor: AMD
- ram: 2GB
- Hard_Drive_Capacity: 250GB
- Monitor/Display Make & Model: 15.6 inch laptop
There's a separate thread here where you can get the red-eye plugin.Ianr wrote:Thanks heaps for this .... just placed the text file in user folder location for it to work for me.
I agree that Grooveman did a nice job laying this out.
Here is the direct link, that was mentioned in this post (though he accidentally forgot the "http" in his bbcode, so it isn't linked and it is easy to miss).Ianr wrote: Cannot find the TinTin redeye plugin anywhere though .. maybe its coming![]()
Bear in mind that mdRedEye, as yet, only works on linux.
Thank you. We'll see, some things might get moved as I use APS more and more, but it is easy to do now that the leg work is donePaul Wossidlo wrote:I agree that Grooveman did a nice job laying this out.
Updated again.
I just found out that kbarni's killer plugin has been released. It is harry and sally combined into one, and it is called Equalizer. It can be downloaded here. (I had to rename the file becuase it ended in .txt. You might need to do the same, that is, remove the .txt extension so the file ends in .afzplug).
Becuase it is both Harry and Sally, it is tough to classify... I put it under B+W, since I use Harry much more than sally. I also moved zchannel mixer onto the Color tab, as I find I'm using it much more for color photos than B+W. You know how to change them if you don't like it...
G
G
2 small corrections: mdRedEyes is different from tin.tin's red-eye plugin (which lanr was asking for). And meanwhile mdRedEyes is also available for Windows and Mac-OS. New link is http://www.deindl.name/ASP-plugins/.grooveman wrote:Here is the direct link, that was mentioned in this post (though he accidentally forgot the "http" in his bbcode, so it isn't linked and it is easy to miss).Ianr wrote: Cannot find the TinTin redeye plugin anywhere though .. maybe its coming![]()
Bye,
Michael
Ah, great! Sorry Michael.
I was cruizing the bibble forums, and came across another great plugin by Kbarni: Grid. It is just a simple over-lay of traditional grids, the golden, ratio, the rule of thirds and the golden selection -- but a very clever tool to help you set up or check the layout of your photo.
So, I have added Grid, and placed it under the "Correction" Tab. I also moved FatToni to the "Tone" tab, if you don't like it there, well, you know what to do to fix that
G
G
Zarastro
- System_Drive: N/A
- motherboard: M4A89TD
- processor: AMD Athlon X6 1075T
- ram: 16 GB
- Video Card: Point Of View GeForce GT 620 1024MB
- Hard_Drive_Capacity: 1300 GB
- Monitor/Display Make & Model: Dell WA2209
Re: Rename, Reorder, and Customize Tabs (Howto)
Just one small correction: the line "Finish1, FNSH1, "com.corel.vigne" should read "com.Corel.vigne" (with a capital "C" in "Corel") or else vigne will not enter the Finish1 Tab.
Hmm... That is not what I find on my system. This is the line:Zarastro wrote:Just one small correction: the line "Finish1, FNSH1, "com.corel.vigne" should read "com.Corel.vigne" (with a capital "C" in "Corel") or else vigne will not enter the Finish1 Tab.
No Capital. In fact, doing as you suggest here removes vigne from my ASP.identifier="com.corel.vigne"
I don't know why you are finding that yours is capitalized, perhaps you have an older version of vigne? Or, perhaps, do you have an unregistered version? According to this, it was last updated on February 6th. Anyone else finding they have a capital "C" here?
