By the way, I was playing around with a photo and was on the Standard tab. The first thing I tried was selecting AutoLevel. I changed the black level from 0.200% to various less aggressive values looking for what looked good. I tried values from 0.200% to 0.003% and there was very little change in the image or the histogram. Blacks were clipped quite a bit with all those values. I then tried 0.002% and suddenly the shadows end of the histogram jumped over to the left.
How to show histogram when using Tone tab?
When I use the Tone tab the histogram that is displayed when using the Standard tab disappears so I can't look at it as I adjust things. I have been searching for a way to view it while in the Tone tab, but haven't found a way. Is there way? If not, why not?
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: How to show histogram when using Tone tab?
I guess the pins for pinning tools are not as obvious as they used to be in Bibble 5.marbly wrote:When I use the Tone tab the histogram that is displayed when using the Standard tab disappears so I can't look at it as I adjust things. I have been searching for a way to view it while in the Tone tab, but haven't found a way. Is there way? If not, why not?
Something is wonky with the autolevel/autocontrast implementation ;-(
cheers
afx
Ahh, that did it. Thanks!afx wrote:I guess the pins for pinning tools are not as obvious as they used to be in Bibble 5.
Okay, glad it isn't just me. I assume a bug report has already been submitted about this?afx wrote: Something is wonky with the autolevel/autocontrast implementation ;-(
afx
- System_Drive: N/A
Well, it has been noted in the beta forums.marbly wrote:Okay, glad it isn't just me. I assume a bug report has already been submitted about this?
More reports usually help prioritizing things.
cheers
afx
claudermilk
Yeah, there's been many posts about autoloevels & autocontrast. They are currently completely broken & completely useless; my best advice there is pretend they don't exist.
You can do a little customization of the tools using hte customUI.txt file. See the blog posting here: http://flightofthebibbles.blogspot.com/ ... -tabs.html
Bibble transplant
Okay, I submitted a bug report. It would be helpful if everyone on these forums who finds a problem would submit a bug report so maybe they will get fixed. I know that I am getting quite annoyed that a very buggy beta or even alpha release got put out as a regular release and I am even more annoyed that I am Corel's unpaid QA person. They are getting a very bad reputation in my book.afx wrote:Well, it has been noted in the beta forums.
For anyone reading this, you can submit bug reports or other things here:
https://www.surveymonkey.com/s/ASPFeedback
