Dual Monitors
Tadjio
- motherboard: Gigabyte
- processor: Core i7 2.8GHz 860
- Video Card: ATI HD5570
- sound_card: Sound
- Hard_Drive_Capacity: 2.5TB
Dual Monitors
There has been some discussion recently about ASP and Dual Monitors.
I have two monitors, with the Windows Desktop extended across both.
Based on my experience with PaintShop Pro, where I have all my Palettes on the second monitor thus freeing up the main one for the image itself, I set out to do the same with AfterShot Pro.
My ASP now has the Left Panel in place on the main screen, together with the Thumbnails and Preview, and the Right Panel (Tools) on my second screen.
After opening ASP, if I use the History, Filter or Layers, these appear on the second screen and while I am Cropping, its Panel appears there.
As a result, if I close the Left Panel ("L") I have the maximum Preview display, with our without Thumbnails.
I cannot find a way to 'un-dock' the Left Panel and move it, which I was able to do with the Right Panel.
My only other wish would be to have a re-sizeable History Panel so that I can make it fit the screen height.
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
Re: Dual Monitors
While a nice workaround - I don't want to have my desktop spread across 2 screens... the difference in resolutions just kills that idea for sure. I want the program to take advantage of 2 or 3 monitors each with its own unique desktop.
jknights
- motherboard: Apple
- processor: Intel 3.08GHz Dual processor Quad Core
- ram: 24GB
- Video Card: ATI Radeon X1600
- sound_card: Intel HDA
- Hard_Drive_Capacity: 6TB
- Monitor/Display Make & Model: Apple Display
Re: Dual Monitors
AFAIK There is no Dual Monitor support in ASP.
I think that you have your machine set up so that it is using a Virtual Desktop that is spread across the two monitors.
Still learning after all these years!
Tadjio
- sound_card: Sound
Re: Dual Monitors
Yes, as I said, my Windows Desktop is extended over two screens, producing the result I would anticipate with ASP.jknights wrote:AFAIK There is no Dual Monitor support in ASP.
What more would you expect with Dual Monitor support in ASP?
Tadjio
ashmoore
- System_Drive: N/A
- ram: 16G
- Monitor/Display Make & Model: iMac 27"
Re: Dual Monitors
Several other apps deliberately drive the second monitor without you needing to drag a single window around over two screens.
Lightroom or Aperture will let you change what is on the second monitor for instance - or simply turn it off or on with a menu/keypress.
old Bibble user
Hmm is that (old) Bibble user or (old Bibble) user?
Tadjio
- sound_card: Sound
Re: Dual Monitors
Yes, PSP has such a Dual Monitor option but it decides what should appear on the second screen and it isn't what I wantashmoore wrote:Several other apps deliberately drive the second monitor without you needing to drag a single window around over two screens.
Tadjio
Re: Dual Monitors
just check out idimager... supports as many monitors as you have setup. You can drag a panel to anyplace on any screen without the need to expand the desktop. This is what we would hope for down the road with ASP... single monitor support is very 90's
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Dual Monitors
So what you want is not multimonitor support.pesto126 wrote:just check out idimager... supports as many monitors as you have setup. You can drag a panel to anyplace on any screen without the need to expand the desktop. This is what we would hope for down the road with ASP... single monitor support is very 90's
What you want us a UI that is not fixed to one containing window. Quite different.
True multimonitor support would entail handling of several screen profiles in rendering and allowing to show an image over several screens with appropriate color management in each.
Quite hard to do.
Detachable panels are much easier (and I still wonder why they are not there yet...)
cheers
afx
Tadjio
- sound_card: Sound
Re: Dual Monitors
Isn't this what we now have with ASP on Windows?afx wrote:What you want us a UI that is not fixed to one containing window. Quite different.
I can detach any panel (apart from the Left Panel) and place it anywhere on a second screen, where they remain happily between sessions.
Tadjio
afx
- System_Drive: N/A
Re: Dual Monitors
Only partly.Tadjio wrote:Isn't this what we now have with ASP on Windows?afx wrote:What you want us a UI that is not fixed to one containing window. Quite different.
Any - hardly. Exactly one....I can detach any panel (apart from the Left Panel) and place it anywhere on a second screen, where they remain happily between sessions.
You can only detach the complete tool panel, but neither the browser nor the thumbs. And for max use of a second screen, being able to detach not the complete tool panel but individual tool tabs would be the optimal solution (Bibble 4 did that...)
cheers
afx
Re: Dual Monitors
Just to note that, although their state is not persistent across sessions, all the other floating panels (crop, filter, etc.) remember their position, at least the do here on my second monitor (win7 64). It would, however, be nice (& probably relatively simple to do) if ASP could remember their state so they would start open if desired.afx wrote:Any - hardly. Exactly one....
Personally I'm not too bothered about the left panel but it would be good to have the option to float that too. The other thing that would help greatly, assuming having Bibble4 type floating panels isn't going to happen any time soon, would be to be able to have multiple columns in the tools panel (or multiple instances with different content) - 3 columns across most of a monitor would allow just about everything I use regularly to display at once without having to switch tabs.
Regards
Rick
claudermilk
Re: Dual Monitors
Multiple columns in the tool panel is effectively the Bibble4 functionality we are asking to get back.
Bibble4 was the high-water mark for UI cusotmization. We could set up our multi-monitor layouts just how we wanted. Each succeeding version has gone backwards from there.
Bibble transplant
Tadjio
- sound_card: Sound
Re: Dual Monitors
As I said in my OP "if I use the History, Filter or Layers, these appear on the second screen and while I am Cropping, its Panel appears there". I make that 5 including the Tools Panel - all the clutter that obscures the Preview Imageafx wrote:Exactly one....
I don't know what Bibble 4 had, but it sounds good...
Tadjio
afx
- System_Drive: N/A
Re: Dual Monitors
Popup tool != Panel....Tadjio wrote: I make that 5 including the Tools Panel .
cheers
afx
Tadjio
- sound_card: Sound
Re: Dual Monitors
Semantics or pedantry?afx wrote:Popup tool != Panel....Tadjio wrote: I make that 5 including the Tools Panel .
I was going to use the (PSP) word Palette but thought I ought to slavishly follow the ASP jargon...
Looking in the Help system, I see they are referred to as Palettes (not Pop-up Tool:-)
So any advance on 5 Panels and Palettes and Pop-ups that can reside on a second screen out of the way
Tadjio
