Audio sync HOW?
harryball
Audio sync HOW?
Post by harryball »
This is driving me mad and it should be simple. Maybe I'm not searching on the right words or something but I can't find any solution that works. Using Pro X4
I have a video file, I have an audio file. Video is loaded in the video track, audio in the Voice track.
HOW in the ... do I sync them? I have the mixer on, I can see the wav graphics, I can see where I want them to line up but either the Video track must slide forward ( and it won't, it's locked on 0 ) or the audio track must slide backward (but it won't slide below 0 start) I've tried splitting, clipping... I can't get it cut just right. All I want is time frame 0 for the video to start at postitive time frame within the audio.
What gives? What am I missing? Why is this so hard?
/RB
Re: Audio sync HOW?
Post by BrianCee »
simply drag a colour block down from the library - put it in front of the video on the video track - RIGHT click over the colour block and from the pop-up choose "Change color duration" - use the time code in the new window to set what you think is approximately the required offset (can be down to one frame). Continue to check and add or subtract single frames from the colour block until you are happy with the sync.
harryball
Re: Audio sync HOW?
Post by harryball »
THANKS!
/RB
