[Plugin] "Red-Eye" removal
Re: [Plugin] "Red-Eye" removal
Hi!
Thanks to JMKnights the Windows and MacOS versions have arrived. Thanks!
http://www.deindl.name/ASP-plugins/ has version 1.2.0 of the plugin. Changes to version 1.1.0 are the addition of Windows and MacOS versions and a German translations.
Translations to other languages are welcome!
Bye,
Michael
Bye,
Michael
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
Hi Michael
If you would like to be able to offer a French language version of this plugin, I should be happy to translate the strings and help for you. I don't know how PMs work in this forum, but if you are interested, you could drop me a line at mike at mikemurphy dot nl
Mike
Mike
Tested, and working great! Thank you Michael!
Thanks to DutchMM we have a French translation now. I increased the version number to 1.2.1 due to this, but no code changes.
Bye,
Michael
I'm happy that people like it.grooveman wrote:Tested, and working great! Thank you Michael!
Bye,
Michael
Hi!
Version 1.2.2 of the plugin is available at http://www.deindl.name/ASP-plugins/.
Only change to previous version is a preliminary Dutch translation (thanks to DutchMM).
Comments on the translation are welcome.
Bye,
Michael
Bye,
Michael
Hi Michael,
Trying to download based on the last link in this thread, but It just times out...
Is there a new link?
Thanks!
G
Thanks!
G
Hi Grooveman,
Bye,
Michael
I tried it a minute ago and it worked. Maybe a temporary outage of my ISP or somewhere on the way from my ISP to you.grooveman wrote:Trying to download based on the last link in this thread, but It just times out...
Bye,
Michael
patrickh
- System_Drive: N/A
- motherboard: Macintosh
- processor: 2.93 GHz Intel Core i7
- ram: 4GB
- Video Card: ATI Radeon HD 5750 1024 MB
- sound_card: MacNone
- Hard_Drive_Capacity: 1Terabyte
- Monitor/Display Make & Model: iMac 27"
Any chance of a Mac version on this one too?
patrickh
patrickh
patrickh
- System_Drive: N/A
- ram: 4GB
Actually posted before you announced the ported version. Many thanks to all of you geniuses who provide these wonderful plugins
patrickh
patrickh
Hi everyone,
I have just installed and tried the plugin and I found what I think are a couple of bugs:
AfterShot Pro 1.1.0.30 on Linux 64bit (Ubuntu 12.10).
mdRedEyes 1.2.2
- Minor: When I enable the plugin for a adjustment layer the 150/80 default values are not applied, i have to double click in sensitivity and luminance so they are set because they start as 10070.
- Critical: Whe I output the image with the correction applied the correction does not show in the JPEG image, it seems like if the plugin was only used at preview time, not at export time
mdRedEyes 1.2.2
lundbech
- System_Drive: N/A
- motherboard: HAL 9000
Probably the same that happened to Texa. Check out the thread http://forum.corel.com/EN/viewtopic.php?f=96&t=48941, in which tintin wrote: "corel changed some pipeline settings with the two latest versions" so some plugins are not executed.realjab wrote:Hi everyone,
Did anyone else notice this or it only happens to me?
mdRedEyes 1.2.2
Hobgoblin
- System_Drive: N/A
Revert to 1.1.0.10 unless you have pressing need to use the newer version.realjab wrote:Hi everyone,
mdRedEyes 1.2.2
Works fine in 1.1.0.10 for me. Mint 14 64bit
R.
a new version of the plugin is in the process to get compiled for all platforms and should be available soon.
I haven't found a way to change that for one plugin.
The new plugin-version has a "reset"-button which puts the default values into all fields.
The new plugin-version fixes that.
Bye,
Michael
That seems to be caused by the layer handling in ASP. That behaviour probably makes sense for filter like plugins the effects of which are combined together.realjab wrote:
As noted in a different post this is indeed caused by changed pipeline behaviour in ASP.
Bye,
Michael
Michael it seems like the version in your web is still 1.2.2. Did you have any trouble with the compilation process or the fix didn't work as expected ?
I don't know much about graphics but I'm a computer programmer and Linux administrator, may I help you in any way?
Thanks.
Thanks.
