[Plugin] "Red-Eye" removal
Hi!
At this URL http://www.deindl.name/ASP-plugins/ you can download a first version of a "Red-Eye" removal plugin.
Usage:
1. Select the red pupil with a circle-layer. For best result make that circle as small as possible and set the "Feather" to the minimal value. 2. Check the "Enable" checkbox of the plugin. What the plugin does is to replace the red-channel of a pixel with the average value of the blue and green channels, IF the red-channel is bigger than 1.5 times this average.
This is the first version of my plugin so a few things are left to do:
* Add controls for sensitivity and darkness of the pupil
* Translate to other languages
* Deal with animal eyes
Bye,
Michael
Edit: changed URL
Usage:
Bye,
Michael
Edit: changed URL
FotoLars
- System_Drive: X
- motherboard: Intel D975XBX2
- processor: Intel QuadCore Q6700
- ram: 8 GB
- Video Card: NVIDIA Quadro NVS 295
- Hard_Drive_Capacity: 8 TB
- Monitor/Display Make & Model: 2xDell 30", 5120x1600 (2x2560x1600)
Re: [Plugin] "Red-Eye" removal
Hi!
Here, tested on several linux computers with different OS and DE flavours, this plugin doesn't show up after the installation.
Anyone seeing the same?
When reinstalled, an error is given:
/home/lars/Downloads/Plugins/AfterShot/mdRedEyes.afzplug
Unable to uninstall existing plugin: mdRedEyes.afplugin
Unable to delete /home/olmur/C/Aftershot/mdRedEye/windows-mac-readme.txt
Please contact the plugin author.
A PM with the logfile is on its way to the developer.
Cheers,
Lars Nilsson
Lund, Sweden
Cheers,
Lars Nilsson
Lund, Sweden
Paul Wossidlo
- processor: AMD
- ram: 2GB
- Hard_Drive_Capacity: 250GB
- Monitor/Display Make & Model: 15.6 inch laptop
I tried loading it on my Win7 machine...
ASP indicates it is there, but I don't see it under either "Plugins1" or "Plugins2". I noticed I have 5 plugins each installed under those two tabs (10 plugins total). Is there a limit to how many plugins you can load in ASP, or how many in each tab?
Paul
Paul
kaymann
- motherboard: ASUS P8P67 PRO REV 3.1
- processor: Intel i-7 6800K
- ram: 32 GB
- Video Card: NVidia GeForce RTX 2060
- sound_card: Onboard
- Hard_Drive_Capacity: 3.5 T
- Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
- Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
I have 5 plugin tabs but this plugin is not showing up...Paul Wossidlo wrote:I tried loading it on my Win7 machine...
Paul
FotoLars
- System_Drive: X
- ram: 8 GB
Hi!
This first version of Michael's plugin only supports Linux.
Cheers,
Lars Nilsson
Lund, Sweden
Cheers,
Lars Nilsson
Lund, Sweden
kaymann
- ram: 32 GB
We will wait then. thanks for the clarification.FotoLars wrote:Hi!
Cheers,
Lars Nilsson
Lund, Sweden
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
@Lars
When I look at my log file, the plugin section starts as follows:
Note that there is one plugin that has no name ... I would bet money (if I had any
) that this is our red eye tool
Mike
Code: Select all
64098.973: Globals: systemhome ../supportfiles
64098.973: Globals: userhome /home/mike/.AfterShotPro
64098.974:
==================== Plugins =====================
Name:
Identifier:
Version: 1.0.0
Path:
Identifier: com.ferdinand-paris.bez
Version: 1.0.0
Path: /home/mike/Dropbox/ASP/Plugins/Bez.afplugin
Identifier: CAQuest
Version: 2.0.1
Path: /home/mike/Dropbox/ASP/Plugins/CAQuest.afplugin
Identifier: sph.FatToni
Version: 0.32.0
Path: /home/mike/Dropbox/ASP/Plugins/FatToni.afplugin
Mike
FotoLars
- System_Drive: X
- ram: 8 GB
Hi!
There is some minor building error in the plugin. It has an internal plugin identifier, name.deindl.mdRedEyes, but this one apparently doesn't register when ASP starts.
If one in the Info.afpxml file changes the wrong path given for windowsLibFile="/home/olmur/C/Aftershot/mdRedEye/windows-mac-readme.txt" to windowsLibFile="" then it loads correctly and shows up in the plugin tabs, even though it still doesn't register itself in ASP.
Cheers,
Lars Nilsson
Lund, Sweden
Cheers,
Lars Nilsson
Lund, Sweden
Hi!
Thanks for your feedback.
I should have mentioned that it currently only runs on Linux. Windows and Mac versions are planned, assuming I find somebody to compile it for me.
I uploaded a new version 1.0.1 of my plugin to home.bawue.de/~olmur/plugins/mdRedEyes.afzplug
It fixes the deinstall problem and the log shows it's registering:
Bye,
Michael
Identifier: name.deindl.mdRedEyes
Version: 1.0.1
Path: <User Home>/Plugins/mdRedEyes.afplugin
76893.424: Registering AfterShot plugin... "Vigne"
76893.424: Registering AfterShot plugin... "mdRedEyes"
76893.424: Registering AfterShot plugin... "zText"
@FotoLars: thanks for your PM. Unfortunately I seem to be unable to reply.Bye,
Michael
andreas
- System_Drive: X
- motherboard: Asus in Workstation and Dell XPS Notebook
- processor: i7-980 and i7-2720QM
- ram: 12GB - 8GB
- Video Card: ATI FireGL
- sound_card: on board
- Hard_Drive_Capacity: 4.5TB Rd10
- Monitor/Display Make & Model: Samsung Syncmaster 2343sw
Dutchmm
- System_Drive: N/A
Great!
But you will need to remove manually the earlier 1.0.0 directory from ~/.AfterShotPro/Plugins - is this hard coded into the manifest?
Mike
Mike
andreas
- System_Drive: X
- ram: 12GB - 8GB
Hm, there are images which get green eyes with the plugin. I think the resulting colour should be always gray:andreas wrote:works here on my Linux box.
Rnew = Gnew = Bnew = (R*sr+G*sg+B*sb)/3*sd
sr, sg, sb are sliders for the colors
sd slider for the darkness in the result
Initial values may be sr=0.2, sg=1, sb=1, sr=1 to nearly eliminate the red channel. For animals perhaps sr=1, sg=0.2, sr=0.8 which can be set up by presets.
Andreas
Linux - not Windows
andreas
- System_Drive: X
- ram: 12GB - 8GB
This may arise when the plugin identifier changed or perhaps when ASP does not recognised the plugin in the former version. ASP should remove all what is included in the Info.afpxml file resp. the whole folder on an update.Dutchmm wrote:But you will need to remove manually the earlier 1.0.0 directory from ~/.AfterShotPro/Plugins
Andreas
Linux - not Windows
Hi!
I uploaded version 1.1.0 to http://home.bawue.de/~olmur/plugins/mdRedEyes.afzplug. Details below.
[quote="andreas]Initial values may be sr=0.2, sg=1, sb=1, sr=1 to nearly eliminate the red channel. For animals perhaps sr=1, sg=0.2, sr=0.8 which can be set up by presets.[/quote]
Good suggestion. Have to think a bit how to arrange the UI for that (without using too much space).
The new version has sliders "Sensitivity" and "Luminance". The algorithm to "remove" red eyes is:
In other words: "Sensitivity" says how much the red-channel has to dominate a pixel to be seen as red eye and luminance is a percentage of how luminant the corrected pixel will be.
Bye,
Michael
You are right. I missread a paper about read-eye removal.andreas wrote: Hm, there are images which get green eyes with the plugin. I think the resulting colour should be always gray:
Code: Select all
mean_green_blue = (green + blue) / 2
If (red >= ((sensitivity * mean_green_blue) / 100): R = G = B = (mean_green_blue * Luminance) / 100Bye,
Michael
ogrizzo
- System_Drive: Q
- processor: 2.8 Ghz Intel Core i7
- ram: 8 GB
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Integrated Apple iMac 27"
Still only Linux?michaeld wrote:Hi!
