Strange pattern on mesh fabric. Olympus E510 raw file.
Denis de Gannes
motherboard: Gigabyte- G31MX-S2
processor: Intel Core Quad CPU Q6700 2.66 GHz
ram: 4GB
Video Card: On Motherboard
sound_card: nk000
Hard_Drive_Capacity: 1820 GB
Monitor/Display Make & Model: AOC 2216Sw
Post by Denis de Gannes »
Conversion done with ASP default settings. Note the strange patterns on the ASP rendition.
The raw file can be made available if required for testing.
Did a further test, if viewed at 100% the pattern is not visible. Nor in an exported file.
Conversion done with Capture one default settings.
Denis
Camera: Oly E300 & E510; ZD & OM Lenses; Panasonic G3
Software: PSP x4; Corel Video Studio Pro X3; PS CS6; SilkyPix 4; ASP 1; LR 5.4; Capture One Ex 7; Qimage Ultimate; VueScan.
tomsi42
Re: Strange pattern on mesh fabric. Olympus E510 raw file.
Post by tomsi42 »
That's a familiar pattern - moire.
Not sure what caused it here. Is this on the output file? What is your sharpening settings on the output queue? And what type of sharpening are you using in ASP?
andysalay
operating_system: Linux
System_Drive: Z
motherboard: ASUS P5E WS PRO
processor: Core2 Quad Q6700
Video Card: AMD Radeon HD 6670
Post by andysalay »
This phenomenon is called moiré.
It is "normal".
http://www.wfu.edu/~matthews/misc/DigPhotog/alias/
http://www.cambridgeincolour.com/tutori ... ensors.htm
http://www.dpreview.com/learn/?/Glossar ... ire_01.htm
EDIT:
Ah, sorry for misread. You have stated that it is not visible in 100% nor exported image. So fortunately this particular case is not sensor moire. It is rather aliasing caused by (simple) downsampling algorithm in viewer code.
So for this case is described as "aliasing" in the first link.
It can be avoided (if it is product of your manual resize in photo editor) with careful selection of resize alorithm and some treatment.
http://www.cambridgeincolour.com/tutori ... or-web.htm
In ASP you can do nothing with it, when it occurs in this place.
Maybe if you introduce some blur, you will avoid it, but with that you will destroy your image, and the only benefit will be better display within ASP on sub-100% magnifications.
Andy Salay
Denis de Gannes
ram: 4GB
sound_card: nk000
OK thanks for the help. It appears the problem is in the preview display of the image and does not affect the final file. I just do not see the same problem in Capture One and Lightroom.
Denis
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
AS uses a relatively simple downscaling algorithm for the previews, I guess for speed reasons.
It used to be even worse....
cheers
afx
marbly
Post by marbly »
In Preferences|Display did you select Show only high quality previews?
Denis de Gannes
ram: 4GB
sound_card: nk000
marbly wrote:In Preferences|Display did you select Show only high quality previews?
Yes I did try and there was no difference.
Denis
afx
System_Drive: N/A
Post by afx »
That only disables annoying intermediate rendering steps...
cheers
afx
