standard view when opening
Gerard2
- processor: AMD Athlon II X4 620 2.61GHz
- ram: 4GB
- Video Card: Ati radeon x1950xtx 512 mb
- sound_card: onboard
- Monitor/Display Make & Model: Dell FP2007
ASP opens always with a row of thumbnails and space for the main picture.
If I last had only thumbnails, it still switches back. Bibble used to remember the last used view...
Is there a way you can force ASP to select a certain view or go to the last view used ?
dFlyer
- System_Drive: N/A
Re: standard view when opening
On the linux version (Ubuntu 11.10) it does remember the last photo selected and loads it when the program starts.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
TexJoachim
- System_Drive: Z
It doesn't, however, respect the last view. As the TO noted: last picture plus preview strip is what opens, even if you closed ASP with a different view.
Joachim
Joachim
Gerard2
- ram: 4GB
I do see it as a small niggle, but would be nice if it opens exactly the same as when it was closed. I rarely use the filmstrip on top view, so I'd rather have it open at the thumbnails on default.
Here on Win7 64 - I get the last image previewed, but always in standard view - whichever view I had when I closed the program.
FWIW ASP remembers the orientation of the thumbs (top or left) in Standard View but doesn't remember a closed left panel (it always starts open). I always have the Tools Panel floated & on my 2nd monitor so haven't bothered playing with that but just note that it reopens where I left it.
Regards
Rick.
Regards
Rick.
claudermilk
On my Win7 64 bit, it will not remember the filmstrip orientation (keeps putting it on top--I want it on the left); however, since I've floated the tools panel to my other screen, it remembers that. It also won't leave any of the other tool panels open (history, etc).
The UI needs a lot of work still.
Bibble transplant
Under Linux I can see the same annoying effect. The left panel is open when AfterShot starts. I want it in the state it had on last AfterShot shut down.RickHeath wrote:FWIW ASP remembers the orientation of the thumbs (top or left) in Standard View but doesn't remember a closed left panel (it always starts open).
ormdig
- motherboard: Asus Sabertooth X58
- processor: Intel i7-950 3.72Gh
- ram: 24Gb
- Video Card: Nvidia GeForce 460
- sound_card: Realtek HD audio
- Hard_Drive_Capacity: 4.5 Tb
- Monitor/Display Make & Model: HP LP2475w, HP LP 2065
How did you float the tool panel to your other screen? I've looked throught the forums but can't find that subject. I thought I had read somewhere that we couldn't do that. I would really appreciate an how to.claudermilk wrote:On my Win7 64 bit, it will not remember the filmstrip orientation (keeps putting it on top--I want it on the left); however, since I've floated the tools panel to my other screen, it remembers that. It also won't leave any of the other tool panels open (history, etc).
The
Thank you.
afx
- System_Drive: N/A
- Video Card: FirePro 4900
View->Toolbars->Float Tools Panelormdig wrote: How did you float the tool panel to your other screen? I've looked throught the forums but can't find that subject. I thought I had read somewhere that we couldn't do that. I would really appreciate an how to.
cheers
afx
ormdig
- ram: 24Gb
afx: Thank you.afx wrote:View->Toolbars->Float Tools Panelormdig wrote: How did you float the tool panel to your other screen? I've looked throught the forums but can't find that subject. I thought I had read somewhere that we couldn't do that. I would really appreciate an how to.
cheers
afx
claudermilk
Yep, as simple as that. Then look at the customToolsUI customization to set up & arrange the tabs and tools just how you like. Now, if we could get the floated toolbars back we would be returned to the Bibble 5 capability. Then give us back the ability to set up multiple custom floated tool panels--like we had in Bibble 4. I could then stop whinging about it.
Bibble transplant
cookiebob
- System_Drive: N/A
- processor: Intel Core i5 CPU M 460 2.53GHz x4
- ram: 4GB
- Video Card: Intel Ironlake Mobile
- Hard_Drive_Capacity: 320GB
- Monitor/Display Make & Model: Asus
This behaviour is very annoying. Bibble 5 was better in this case and hope it'll be fixed the newest ASP update.Gerard2 wrote:ASP opens always with a row of thumbnails and space for the main picture.
