Plugin Sources from Thomas Baruchel
AfterShot Pro Plugins
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
anyone interested in porting the Plugins from Thomas Baruchel?
I have some of the sources at
http://afximages.com/stuff/plugins/Baru ... ources.tgz
Aaron
Bathsheba
Bathsheba_Solomon
LabColors
LabContrast
LabCurves
NegativePositive
SelectColor
SimpleFrame
They all are based on the Bibbe 5.0 API, so some effort is required to make them work in AS.
My feeble attempt a porting MathBox to AS is at
http://afximages.com/stuff/plugins/Math ... Source.zip
I just don't find the time to clean it up and document it properly.....
Here is a compiled version (thanks to Jonathan):
http://afximages.com/stuff/plugins/Mathbox_WML.afzplug
cheers
afx
TexJoachim
System_Drive: Z
Re: Plugin Sources from Thomas Baruchel
Post by TexJoachim »
Which computer language do I need to know to port plugins, BTW?
Joachim
spoilerhead
System_Drive: N/A
Hard_Drive_Capacity: 13.5TB
Post by spoilerhead »
C++ with QT, and you need access to the ASP SDK (available on request)
my ASP Plugins - donation button ( send beer! :) )
linux,7d, glass and a huge mug of coffee.
If you got any immediate problems with my plugins, don't by shy on contact me on GoogleTalk.
ferdinand-paris
motherboard: GA-X58A-UD3R
processor: 3.20 gigahertz Intel Core i7 960
ram: 4Gb
Video Card: NVIDIA GeForce 7300 GS
sound_card: Realtek High Definition Audio on-board
Hard_Drive_Capacity: 2500 Gb
Monitor/Display Make & Model: Eizo CG222W
Post by ferdinand-paris »
My response in the other place: [link removed]
Last edited by ferdinand-paris on Sat Feb 25, 2012 8:57 am, edited 1 time in total.
gareth
operating_system: Windows 8.1
motherboard: Acer Aspire TC-605
ram: 12Gb
Video Card: NVIDIA GeForce GTX 745
Hard_Drive_Capacity: a few TB
Monitor/Display Make & Model: AOC 2369M sRGB
Post by gareth »
Unfortunately I have not written in the right languages but I would certainly be willing to make a small donation for LabCurves/LabColors which I use with B5 for solarisation and tweaks.
ex-Bibble - mostly OLY E-510 and E-M5 + Win 8
MikeFromMesa
operating_system: Mac
System_Drive: N/A
processor: 3.0 GHz Intel Core i7
ram: 16 GB
Video Card: Intel Iris
Hard_Drive_Capacity: 256 GB SSD
Monitor/Display Make & Model: 24" Dell Ultrasharp Monitor
Corel programs: PaintShop Pro, AfterShot Pro
Post by MikeFromMesa »
spoilerhead wrote:C+ with QT, and you need access to the ASP SDK (available on request)
I am sorry, but exactly what are you saying here? I know c, c++ and c# but I have never heard of c+. Is it a mistype? When I googled c+ all I got was c++, QT-C++ and c+-. Do you mean QT with C++?
TexJoachim
System_Drive: Z
ferdinand-paris wrote:My response in the other place: http://support.bibblelabs.com/forums/vi ... 42#p100842
This gives me "You are not authorised to read this forum." and, yes, I'm a registered user there.
Joachim
afx
System_Drive: N/A
Post by afx »
TexJoachim wrote:This gives me "You are not authorised to read this forum." and, yes, I'm a registered user there.
Registered Plugin developers only....
cheers
afx
FotoLars
System_Drive: X
motherboard: Intel D975XBX2
processor: Intel QuadCore Q6700
ram: 8 GB
Video Card: NVIDIA Quadro NVS 295
Hard_Drive_Capacity: 8 TB
Monitor/Display Make & Model: 2xDell 30", 5120x1600 (2x2560x1600)
Post by FotoLars »
Hi!
In terms of demand for the plugins afx mentions, I for one would be interested in having:
Aaron
Batsheba (preferably the Uriah version, but that one I believe was not developed further in the age of B5...)
Channel Mixer
Lab Colors
Lab Curves
Select Color
Simple Color Filter
Cheers,
Lars Nilsson
Lund, Sweden
spoilerhead
System_Drive: N/A
Channel Mixer should be obsoleted by zChannelMixer i think:
http://aftershotpro.com/plugins/?plug=zchannelmixer
FotoLars
System_Drive: X
ram: 8 GB
Post by FotoLars »
spoilerhead wrote:Channel Mixer should be obsoleted by zChannelMixer i think:
Hi!
Yes, that is absolutely correct!
Copying and pasting text from a list to another sometime give rather unwanted results...
Thanks for pointing this out :-) !
Cheers,
Lars
ferdinand-paris
ram: 4Gb
Sorry. In my haste I hadn't noticed where that had been posted on the other place. What I said was:
As I said previously, given that most of these are just tonality plugins then it shouldn't be hard using an existing port of a tonality plugin (like Bez) as a template. The question is, which ones are needed most?
Half of Lab contrast is in Bez.
Do we need Simple Frame given that we have zFrame (and given that it's likely to be harder)?
One of us might have a go at one or two if there is some sign of demand.
Gareth at least nominated only one, for starters. FotoLars should specify some sort of priority order. Long unordered lists won't advance the cause. Some understanding of why something is important would help to motivate plugin authors - as it will still take some time and testing. No-one will want to put the effort in just on a whim. If these get done they will probably be done one at a time over a period of time. I'm not sure when I could start if I volunteered to do one, as the port of Bez took a lot longer than I had budgeted for (largely my own fault), and I am way behind on other things.
F_P
FotoLars
System_Drive: X
ram: 8 GB
Post by FotoLars »
Naming one plugin, my vote would go to LabColors. Sometimes it has shown to be useful in B5.
The rest in my former list can be omitted.
Lars
hannes_hab
System_Drive: Z
motherboard: ASUSTeK P8H77-I
processor: Intel Core i7 3770K 3.5 GHz x 8
ram: 16 GB
Video Card: AMD Radeon R7 200 Series
sound_card: Radeon HD 7700 7800 Sapphire
Hard_Drive_Capacity: 2x250GbSSD
Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
Corel programs: AfterShotPro 1, 2, (3)
Post by hannes_hab »
would be nice to have:
Select Color - use it to make backgrounds for panorama - photos
Simple Color Filter - to change one color ... Seans Dinky (Digital Ink and Light) would be another tool to do that - don't know if it will be updated for ASP
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
kkjensen
System_Drive: N/A
Post by kkjensen »
Is Mr Baruchel not going to be developing anymore?
