Plug-in installation help.
Charles+OK
- processor: AMD X2 64
- ram: 4GB
I'm having no luck installing Wavelet Denoise and Wavelet Sharpen. The instructions on at aftershotpro.com indicate launching the ".afzplug" file or using the ASP install plug-in function. I cannot find such anyway in the downloads no does ASP. What am I doing wrong? I'm running Vista.
Thanks,
Charles
Thanks,
Charles
bananahead
- motherboard: Asus P67
- processor: i7 2600k
- Video Card: Nvidia 650
- sound_card: Asus DX
- Hard_Drive_Capacity: Lots
- Monitor/Display Make & Model: NEC PA272W
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Plug-in installation help.
You did not look at the obvious placeCharles+OK wrote: What am I doing wrong?
File->Install plugin...
cheers
afx
ferdinand-paris
- motherboard: GA-X58A-UD3R
- processor: 3.20 gigahertz Intel Core i7 960
- ram: 4Gb
- Video Card: NVIDIA GeForce 7300 GS
- sound_card: Realtek High Definition Audio on-board
- Hard_Drive_Capacity: 2500 Gb
- Monitor/Display Make & Model: Eizo CG222W
Not all. Some plugin authors haven't been given access to this facility.bananahead wrote:All plugins should be available from here
The plugin site
F_P
Charles+OK
- ram: 4GB
afx wrote:You did not look at the obvious placeCharles+OK wrote: What am I doing wrong?
cheers
afx
I did that. ASP doesn't see a ".afzplug" file at either my original download location or the default Corel application directory where I moved the unpacked download. Wavelet sharpen downloads as "WaveletSharpen_ALL_T34.zip. Inside I can't find any ".afzplug" files. The same is true for Denoise and the vignetting "gift." Do I need to be in the administrative log-in? I started to check angle, but as I'd installed ASP from a "user" log-in, ASP there was still in uninstalled trial download status. I wasn't sure what a second configuration would do.
Charles
afx
- System_Drive: N/A
Throw away your web browser.Charles+OK wrote:Wavelet sharpen downloads as "WaveletSharpen_ALL_T34.zip. Inside I can't find any ".afzplug" files.
afzplug files are ZIP files. The browser tries to be intelligent and renames them.
Not really smart.
cheers
afx
claudermilk
Yes, the files fhould have .afzplug extensions. To install, I simply double-click the file; ASP loads up and installs the plugin. If I already have it installed, ASP asks if I want to upgrade and shows the currently-installed version and the new file version. It then asks if I wnat to restart now or later.
Bibble transplant
Charles+OK
- ram: 4GB
afx wrote:Throw away your web browser.Charles+OK wrote:Wavelet sharpen downloads as "WaveletSharpen_ALL_T34.zip. Inside I can't find any ".afzplug" files.
Not really smart.
cheers
afx
If I manually rename them, it should work?
afx
- System_Drive: N/A
Sure...Charles+OK wrote:If I manually rename them, it should work?
Unless the ZIP is hosed somehow...
cheers
afx
Charles+OK
- ram: 4GB
Charles+OK wrote:afx wrote:Throw away your web browser.Charles+OK wrote:Wavelet sharpen downloads as "WaveletSharpen_ALL_T34.zip. Inside I can't find any ".afzplug" files.
Not really smart.
cheers
afx
Tried it and the ASP icon appeared instantly and it installed. Thanks ... thanks... thanks!afx wrote:Sure...Charles+OK wrote:If I manually rename them, it should work?
cheers
afx
