I am sure that you must be able to do it...surely..
but how can you see images side by side, so that the original is on the left and the edited on the right?
Thank you
I'm a newbie
View RAW side by side for editing
Imjinman
- motherboard: PEGATRON CORPORATION 2AB6 1.04
- processor: 3.40 gigahertz Intel Core i7-2600
- ram: 8176 Megab
- Video Card: AMD Radeon HD 6570 [Display adapter]
- Hard_Drive_Capacity: 40GB
- Monitor/Display Make & Model: Del2410
andysalay
- System_Drive: Z
- motherboard: ASUS P5E WS PRO
- processor: Core2 Quad Q6700
- Video Card: AMD Radeon HD 6670
Re: View RAW side by side for editing
Create a new version with INSERT key, move focus to this version
(optional) if you have already done some edits hit CTRL-R to clear edits on this new version
select both versions, turn on multiimage view with M key.
PS: you can also use command "New version from defaults". So you can skip CTRL-R step.
Andy Salay
Andy Salay
Just seconding Andy's suggestion & noting that the original will end up on the right & edited on the left unless you do the CTRL+R on the original rather than the newly created version if the order matters to you.
Regards
Rick
Regards
Rick
