I assume this has probably been asked before but I could not find the actual question in my search. Does ASP support dng files?
When I try to open a specific file (File -> Open File) ASP shows me the dng files in the folder dialog box and there is a specific selection for dng files. But when I try to actually open one of the files I am show it does not open. Further the ASP "filmstrip", when I select a folder with dng files in it, does not show any of them. So I am puzzled.
If ASP does not support dng files why is there a selection under File -> Open File for dng files? And if it does support dng files why can I not open a dng file and why do they not display in the "filmstrip"? Or am I missing some basic setting?
I have checked the user guide but cannot even find "dng" in it.
ASP and DNG files
MikeFromMesa
- System_Drive: N/A
- processor: 3.0 GHz Intel Core i7
- ram: 16 GB
- Video Card: Intel Iris
- Hard_Drive_Capacity: 256 GB SSD
- Monitor/Display Make & Model: 24" Dell Ultrasharp Monitor
- Corel programs: PaintShop Pro, AfterShot Pro
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: ASP and DNG files
You need to improve your search skills....MikeFromMesa wrote:I assume this has probably been asked before but I could not find the actual question in my search. Does ASP support dng files?
AS supports only DNGs straight from cameras, not Adobe generated DNGs.
cheers
afx
MikeFromMesa
- System_Drive: N/A
- ram: 16 GB
Anything is possible, but I loaded the AfterShot Pro User's Guide in my pdf reader and did a search for "dng". Nothing showed up and I got the message that "No matches were found". It is hard to see what else I could have done to find references in the User's Guide. I suppose I could actually read it ...You need to improve your search skills....
I can easily believe that. Figures ... And thanks.AS supports only DNGs straight from cameras, not Adobe generated DNGs.
afx
- System_Drive: N/A
I was referring to the forum which was implied in the way you worded your question.MikeFromMesa wrote:Anything is possible, but I loaded the AfterShot Pro User's Guide in my pdf reader and did a search for "dng". Nothing showed up and I got the message that "No matches were found". It is hard to see what else I could have done to find references in the User's Guide. I suppose I could actually read it ...You need to improve your search skills....
cheers
afx
B4b5
This might help...MikeFromMesa wrote:I assume this has probably been asked before but I could not find the actual question in my search.
http://forum.corel.com/EN/viewtopic.php?f=90&t=45154
MikeFromMesa
- System_Drive: N/A
- ram: 16 GB
B4b5:
Thanks. It did.This might help...
