zText
AfterShot Pro Plugins
Hobgoblin
operating_system: Linux
System_Drive: N/A
Re: zText
Post by Hobgoblin »
SRSorg wrote:Where can I find zText for Bibble 5??? NOT After Shot Pro.
Try the Bibble Forum?
http://support.bibblelabs.com/forums/vi ... 986#p95986
R.
greerd
System_Drive: Z
processor: Intel i7 920
ram: 12 GiB
Video Card: nVidia GeForce 260
sound_card: Onboard
Hard_Drive_Capacity: 5 TB
Monitor/Display Make & Model: Dell UltraSharp U2410
Re: zText
Post by greerd »
Try this:
http://support.bibblelabs.com/forums/vi ... 98&t=18944
tintin
processor: Ryzen R5 3600X
Re: zText
Post by tintin »
the thread...
the latest version...
my plugins on the official plugins homepage
If you find my plugins helpful, please make a donation to support further developments - just click here, thank you!
tintin
Re: zText
Post by tintin »
hi,
i finally can provide an update with some new tags added to the plugin.
changelog:
  • new tags introduced:
    • %YEAR%, year of shot as 4 digit value, e.g. "2012"
    • %YEAR-yy%, year of shot as 2 digit value, e.g. "12"
    • %MONTH%, month of shot as 2 digit value, e.g. "08"
    • %MONTH-mmm%, month of shot in 3 letters, e.g. "Aug"
    • %MONTH-long%, month of shot as string, e.g. "August"
    • %DAY%, day of shot as 2 digit value, e.g. "17"
the new version is placed on the aftershot-plugin-page under following link:
http://aftershotpro.com/plugins/index.html?plug=ztext
enjoy texting!
tintin
lathspell
Re: zText
Post by lathspell »
Great, thank you. Any chance to get an adjustable line-height (e.g. in %) in a future version?
tintin
Re: zText
Post by tintin »
lathspell wrote:Any chance to get an adjustable line-height (e.g. in %)
mh, i think i do not really understand what you mean.... :?
lathspell
Re: zText
Post by lathspell »
You've got a PM. :)
tintin
Re: zText
Post by tintin »
aahhh, the line spacing.... i'll see if that is possible...
lathspell
Re: zText
Post by lathspell »
Thanks. I'm patient. :)
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: zText
Post by afx »
Martin,
could you please check the crop handling?
Using zText on an image with a 1.5 aspect ratio where a crop with an aspect ratio of 2 is applied will cut off part of the text.
cheers
afx
tintin
Re: zText
Post by tintin »
sorry for the late reply... i've been away some days...
did you try the same with leaving the crop-cursor-mode?
as long as you stay in crop-mode the image is handled completely by the pipe-line. when crop-mode is left only the cropped image is handled this changes a lot for the plugin.
and could you please tell the whole zText-settings?
afx
System_Drive: N/A
Re: zText
Post by afx »
tintin wrote:did you try the same with leaving the crop-cursor-mode?
I am actually using a preset in a queue, I applied it with corp cursor mode active only to make the screenshot.
cheers
afx
zCopyright.xmp
(2.05 KiB) Downloaded 533 times
tintin
Re: zText
Post by tintin »
thanks AFX, i'll have a look at it later today evening.
br,
tintin
tintin
Re: zText
Post by tintin »
so, i have checked it now....
the phenomenon you are describing is normal zText behavior. the reason is that you have positioned the text near the bottom line of the image. this happens through y-pos-slider. this setting moves the mid-point of the drawn text in the set direction. the problem is that this is referred to the edge length but independently of the text width, means a small text would be needed to be moved more than a long text. through that it depends also on the edge length when having constant text-lenght, which is your case....
you can overcome this problem with using the setting 'vertical position' on the 'preset'-tab of zText. just set it to 'bottom' while leaving the Y-pos setting on the 'Basic'-tab at 50.0.
i have prepared that for you in the preset attached...
br,
tintin
p.s.: might similarly useful for the horizontal position as well...
zCopyright2.xmp
(2.05 KiB) Downloaded 524 times
afx
System_Drive: N/A
Re: zText
Post by afx »
Cool, thanks!
afx
