zText
AfterShot Pro Plugins
tintin
processor: Ryzen R5 3600X
Re: zText
Post by tintin »
...and can you please test and tell me whether the donate button does work?
thanks,
tintin
my plugins on the official plugins homepage
If you find my plugins helpful, please make a donation to support further developments - just click here, thank you!
FotoLars
operating_system: Linux
System_Drive: X
motherboard: Intel D975XBX2
processor: Intel QuadCore Q6700
ram: 8 GB
Video Card: NVIDIA Quadro NVS 295
Hard_Drive_Capacity: 8 TB
Monitor/Display Make & Model: 2xDell 30", 5120x1600 (2x2560x1600)
Re: zText
Post by FotoLars »
Hi again, tintin
While moving the mouse arrow over the donate button with "focus follows mouse" activated in the desktop environment (KDE in this very case) as I always have, the donate frame area becomes active and the arrow becomes a hand. If the hand presses the donate button, the entire window closes immediately. If the mouse arrow clicks the Close button, the window disappears right away and the mouse arrow becomes a hand. This hand can't do anything in ASP except minimising/maximising the ASP window. Kill, etc then must be used in order to terminate ASP.
The reset button works as expected.
The logfile will come in a PM!
Cheers,
Lars Nilsson
Lund, Sweden
maggus
System_Drive: B
Re: zText
Post by maggus »
Hi tin.tin,
just tested zText 2.1.2 ...
same results as FotoLars reports here.
Code: Select all
70594.92: ContainerAsset could not get path by ID
70594.96: Container __CATALOG_ROOT__/assets
70594.98: Container __CATALOG_ROOT__/assets/tmp
70594.101: Container __CATALOG_ROOT__/assets/tmp/_markus_
70594.105: Container __CATALOG_ROOT__/assets/tmp/_markus_/foto
70594.108: Container __CATALOG_ROOT__/assets/tmp/_markus_/foto/ASP-Test
70594.110: set sort order ascending
70594.112: Container __CATALOG_ROOT__/assets/tmp/_markus_/foto/ASP-Test/raw_2
70594.338: viewmode: 1
70594.645: Starting import with settings :  "<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP Core 4.4.0">
 <rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
  <rdf:Description rdf:about=""
    xmlns:bibp="http://www.bibblelabs.com/BibblePrivate/5.0/"
   bibp:MoveCopy="2"
   bibp:LibraryLoc=""
   bibp:LibraryID="2041"
   bibp:LibraryUuid="{4efcdfe6-c7df-c045-a4ef-6b60d6cc0306}"
   bibp:Organize="0"
   bibp:FolderTemplate=""
   bibp:Recurse="false"
   bibp:RenameOn="false"
   bibp:FileTemplate=""
   bibp:ImportPath="/tmp/_markus_/foto/ASP-Test/raw_2"
   bibp:KeywordList=""
   bibp:FolderFilter=""
   bibp:QueueName=""
   bibp:QueueType="0"
   bibp:QueueOnlyNewFiles="false"
   bibp:JobName=""
   bibp:PresetList=""/>
 </rdf:RDF>
</x:xmpmeta>
70594.646: Adding master versions
70594.897: Adding master versions
70594.903: Scanning file  "/tmp/_markus_/foto/ASP-Test/raw_2/IMG_0255.CR2"
70594.914: Scanning file  "/tmp/_markus_/foto/ASP-Test/raw_2/IMG_1367.CR2"
70594.916: Scanning file  "/tmp/_markus_/foto/ASP-Test/raw_2/img_0086.cr2"
70595.550: CAQuest: Hotness Change
70595.550: CAQuest: SettingChanged Event
70595.550: Preset Now
70595.551: ----
70595.665: CAQuest: Settings Change
70595.665: CAQuest: SettingChanged Event
70595.665: Preset Now
70595.665: ----
70595.716: Extracting RAW data:  "/tmp/_markus_/foto/ASP-Test/raw_2/img_0086.cr2"
70595.771: Decoding RAW data:  "/tmp/_markus_/foto/ASP-Test/raw_2/img_0086.cr2"
70601.44: zText about dialog before 'exec'
cheers
Markus
OpenSuse 11.4 (32bit)
Dell U2410
Hobgoblin
System_Drive: N/A
Re: zText
Post by Hobgoblin »
tintin wrote:...and can you please test and tell me whether the donate button does work?
thanks,
tintin
Hi tintin,
Using Mint 11(Ubuntu) clicking on the Donate Button opens Firefox 10.0.2 but does not pass the URL to the browser.
This is a documented problem with Firefox and Linux. You possibly need to include a text for the URL link on the help page as well.
The button does work if the default browser is Chromium.
R.
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: zText
Post by afx »
Hobgoblin wrote:Using Mint 11(Ubuntu) clicking on the Donate Button opens Firefox 10.0.2 but does not pass the URL to the browser.
Really?
Works like a charm on my 11.10 Xubuntu.
cheers
afx
greerd
System_Drive: Z
processor: Intel i7 920
ram: 12 GiB
Video Card: nVidia GeForce 260
sound_card: Onboard
Hard_Drive_Capacity: 5 TB
Monitor/Display Make & Model: Dell UltraSharp U2410
Re: zText
Post by greerd »
Works fine on my Unity 11.10 too, with zText 2.1.0.
Zarastro
System_Drive: N/A
motherboard: M4A89TD
processor: AMD Athlon X6 1075T
ram: 16 GB
Video Card: Point Of View GeForce GT 620 1024MB
Hard_Drive_Capacity: 1300 GB
Monitor/Display Make & Model: Dell WA2209
Re: zText
Post by Zarastro »
Besides the issues with the "about" button which I also have experienced - Fedora 16 64bit here - I'd like to see an option to zText to add embossed texts such as those generated by this ImageMagick code which I run when I convert my pictures for web publication:
Code: Select all
composite -dissolve 50 -gravity southwest ~/fotos/utils/stamp.png
The final result looks like this:
In this example, "composite" combines the image ~/fotos/utils/stamp.png (which contains my text signature, as prepared per IM's instructions - see this link and go to "Using a Mask Image with Fonts" in the end of the page. I don't know if ASP provides the needed routines to do the job, of you'd have to write the code yourself or if you could get a hook from IM's binaries to implement this feature - say, "check for IM's binaries and, if they are present, then use it to do the necessary processing" as per the recipe I've indicated here.
Hobgoblin
System_Drive: N/A
Re: zText
Post by Hobgoblin »
Really?
cheers
afx
Nope, Donation Button won't work on my installation.
May be a Mint 11 issue, although the correct settings are in Gconf. :cry:
Not an issue on Win XP or Win7 ...
R.
PC(s): Linux Mint 18
Laptop:Linux Mint 18
Photo Software:
Darktable 2.0.4 http://www.darktable.org/
AfterShot 2 Pro
Cameras: Pentax: K-5 & Olympus TG-4
afx
System_Drive: N/A
Re: zText
Post by afx »
I suspect an interaction with the Windowing system.
Could those that have problems switch to something else for a test?
I use XFCE....
cheers
afx
Hobgoblin
System_Drive: N/A
Re: zText
Post by Hobgoblin »
afx wrote:I suspect an interaction with the Windowing system.
I use XFCE....
cheersht
afx
Hi AFX,
Have just experimented with XFCE.
Donate Button links correctly to Firefox, seems you may well be right about Windowing system. :?
Thanks for the thought,
R.
Photo Software:
AfterShot 2 Pro
dFlyer
System_Drive: N/A
Re: zText
Post by dFlyer »
Other than the pop up box saying zFrame instead of zText all the buttons work including the link to the donation button, with Ubuntu 11.10 Unity. No lockups or crashes.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
maggus
System_Drive: B
Re: zText
Post by maggus »
Hi tin.tin,
seems to be a well hidden problem .... did you get in contact with one of the developers of the plugins where the popup does not cause the freeze (ref. HERE) ... maybe they have some idea or can provide their <?> button handling code for comparison ?
I see two major differences in your popup compared to all others:
  • your window has no border/title-bar/decorations, just the plain content visible
  • all other have only simple multi line text + an icon, your popup looks more like some HTML document ?
Maybe try the following steps:
  • enable border/title-bar/etc. for your popup
  • skip the <donate> button
  • use simple multi line text
best regards
Markus
Dell U2410
ogrizzo
operating_system: Mac
System_Drive: Q
processor: 2.8 Ghz Intel Core i7
ram: 8 GB
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Integrated Apple iMac 27"
Re: zText
Post by ogrizzo »
Zarastro wrote:Besides the issues with the "about" button which I also have experienced - Fedora 16 64bit here - I'd like to see an option to zText to add embossed texts such as those generated by this ImageMagick code which I run when I convert my pictures for web publication
Doesn't the shadow option render text in a very similar way?
Zarastro
System_Drive: N/A
ram: 16 GB
Re: zText
Post by Zarastro »
No. Here's an example of embossing. The effect I'd like for zImage would be embossing the text, making it transparent and then adding it to an image to make a watermark.
B4b5
Re: zText
Post by B4b5 »
Zarastro wrote:adding it to an image to make a watermark.
Would SadMan's Texa plugin help?
