Default Cropping
Roedy
motherboard: ASUS M5A88-M
processor: AMD FX-6100
ram: 16 GB
Video Card: Radeon
sound_card: Realtek
Hard_Drive_Capacity: 250 Gig
Monitor/Display Make & Model: Samsung SyncMaster 2443BW
Default Cropping
Post by Roedy »
I do a huge amount of mindless image cropping -- book covers from Amazon.com. They always come with a white bar down each side. It would be nice if when I clicked CROP the rectangle were accuartely posititioned so all I had to do was double click. As it is, it takes a fair bit of fiddling to get it bang on starting from the idiotic default setting. The default seems to be the correct setting, then randomly jiggled to make it wrong.
If what I say makes no sense, try cropping a few bookcover images from Amazon.com. All should come clear.
There is also a bug, probably disguising itself as a feature, that when I get the position of the crop rectangle almost right, it suddenly jumps back to the old position. That is so infuriating.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Default Cropping
Post by LeviFiction »
I just tried it and the crop rectangle always positions itself in the same location for me. The book cover, of course, is of a different size or shape some times so that puts it slightly off. But otherwise the starting point and size are exactly the same just as it should be.
I have never experienced that bug but it's not a feature.
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
You would have loved using PSP7 and the versions prior to that for cropping. You could crop your first image and then just double-click the crop tool button to bring up the Crop Area dialog. It would remember your last settings so all you had to do was click OK to apply then repeat to get the same selection over and over.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Post by Radim »
For (correcting small rotation) and cropping a lot of images I use ScanTaylor - http://scantailor.sourceforge.net/?q=en/node/3
When I scanned my paper books it takes 10 times less time :D to do work against the same in PSP X3/X4. So try it, will see difference...
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
Like what Levi mention the crop tool will keep the last known setting of the last crop that you made and carry-it-over to the next image that you will be cropping. Unless of course the next image is too small of the previous crop settings.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
brucet
operating_system: Windows 8.1
Post by brucet »
OK another crop issue.
I was playing around with the crop tool and now I can't get back to where it acts 'normal'!!!!! I've used it for years and this has me baffled.
I have 3 layers. Background(copy of layer 1)/Layer 1/Layer 2.
With layer 2 active I do a crop. Freehand most often.
If for any reason I don't like the results I click the undo arrow or go to Edit/Undo. Now for whatever reason my top layer dissapears and I get a copy of the layer 1. The original layer 2 has gone. Zap. On the moon or mar. But it's gone. What ever I do I can't get my Layer 2 back. I have to close the file and start over.
Is there away of reseting just the Crop feature back to the way Corel delivered it to me?
Thanks.
Roedy
ram: 16 GB
Video Card: Radeon
sound_card: Realtek
Post by Roedy »
Roedy wrote:If what I say makes no sense, try cropping a few bookcover images from Amazon.com. All should come clear.
The width of the bars to be cropped off are different for every book. I suspect though that most Amazon book images all start out the same size. The auto-crop I am after would have to analyse edges/colours, not simply remember the position of the crop from the previous image. It would not have to be too clever. I think most of the time the bars to be chopped are pure white. I have thought of writing my own software to do the chopping.
