I have Ulead Videostudio 9. Yes I know it is old but it does the job for me.
I am trying to capture from a DVD and following the manual instructions all goes OK up to the Import step. At that stage I get an error message "Temporary working forder does not exist. Report ID 0x8004083d(2109)" First time I have tried to capture stuff from a DVD.
Program still works fine on all other aspects.
I have checked the closed Ulead Forum and FAQ's but can find no solution. Is there anything I can do?
Rusty
Trying to capture from DVD using VS9
rustyhelen
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Re: Trying to capture from DVD using VS9
I presume that you have made a working folder?See pages 163 and 167 of the VS9 manual
rustyhelen
Hi and Thanks Kenneth.
It is usually the simple things. When I first read your suggestion I thought of course I have a working folder. But thought I would check anyway and sure enough it was looking for an "old" hard drive ID letter. I had some work done on the PC recently and as part of that the hard drive ID's were changed. Simple fix and now all OK.
Thanks again.
Rusty
Thanks again.
Rusty
I am a newcome to video editing and have ULead Video Studio 9. I did not realize it was an older version.
It is difficult for me to understand, especially editing scenes and deleting scenes I do not want.
Manual is very confusing, and I have spent hours trying to edit. No problems in capturing and titles.
Can you help ?
Can you help ?
Almost certainly we can help CAW - but help with what ? - what is your specific problem ? - if you are just having basic problems using VideoStudio then first have a read through all the tutorials here :- http://forum.corel.com/EN/viewforum.php?f=27 - then go to Youtube and put VideoStudio into the search bar and you will be shown a large number on how to use all aspects of VideoStudio - have a look through some of those - the basics are the same in all versions it's just that you can do more in the later versions.
