I've got a project file that I've been working on for a few weeks. I made a couple of changes to it today and now it will not play through completely. It stalls right at the same spot each time and no matter what I delete in the project (trying to remove the offending element) it still stalls. What I mean by stall is that the player stops and the play button reappears. if I press play again, it plays a few frames and stops. any suggestions.
I'm using VideoStudio 4.
Thanks,
Wayne
corrupted project file (help)
Re: corrupted project file (help)
What is the format of the video files in the project? Right click on one of them in the timeline or the VS library window and copy all its Properties here, please. If there is more than one type of video, do the same for the other types as well. Also, have you applied any special filters around the problem point or done anything else special around that point?
Thanks for the note Mr Berry but I think I've got it figured out. I had inserted an image in the middle of the project. Once I removed the inserted image things started working properly again. I've reinserted it and it seems to be working now.
thanks again for the response,
Wayne
Wayne
