[plugin] Nuance Colour Grading tool released!
AfterShot Pro Plugins
seanmpuckett
operating_system: Mac
System_Drive: N/A
Re: [plugin] Nuance Colour Grading tool released!
Post by seanmpuckett »
An update for the crashing issue is being tested.
I create plug-ins for AfterShot Pro! See http://nexi.com/afplugs
charlot
motherboard: Dell xps8300
processor: i7 26
ram: 16gb
Video Card: amd Radeon HD6770
sound_card: on motherboard
Hard_Drive_Capacity: 2to
Monitor/Display Make & Model: Dell Ultrasharp U241
Post by charlot »
Reinstalled 1.08...no crash with Win7
Thanks for reply
Charlot
seanmpuckett
System_Drive: N/A
Charlot, check your private messages. Thanks.
charlot
processor: i7 26
ram: 16gb
Post by charlot »
Hi Sean
Tried new version
Works O.K. enable Nuance..ma p for colors ..click a color .... no crash....Chose color put the cursor to extreme...reset no crash and i used a former image that crash before tried on several images ...no crash
CHEERS
Charlot
Color picker ?? :D
bananahead
motherboard: Asus P67
processor: i7 2600k
Video Card: Nvidia 650
sound_card: Asus DX
Hard_Drive_Capacity: Lots
Monitor/Display Make & Model: NEC PA272W
Post by bananahead »
Thanks Sean. History problem is fixed :D
ChrisC
motherboard: Intel HM65
processor: Intel Core i7
ram: 8 GB DDR3
Video Card: AMD Radeon HD6770M
sound_card: Beats Soundsystem
Hard_Drive_Capacity: 750 GB
Monitor/Display Make & Model: HD+ High-Definition LED HP BrightView Display
[plugin] Nuance Colour Grading tool - BUG in version 1.0.9?
Post by ChrisC »
Since version 1.0.9 (full version) ASP crashes every time I hit the reset button of Nuance!?
Is there a log or something I can provide to help finding the problem?
P.S. the more I use Nuance the more I not only find it useful but also fun to toy with - thanks for this plugin
ChrisC
ram: 8 GB DDR3
Post by ChrisC »
one question and one feature request...
Question:
Is is correct that the batch color I choose always alters the color region of the original image?
What I mean is:
If I have changed the colors using Nuance and some previous blues got green and then try to change the green batch -> only the original green regions are effected (not the ones I have turned to green using nuance)?
Feature Request:
Would it be possible to reset the values via double click?
thanks
chris
seanmpuckett
System_Drive: N/A
Nuance 1.0.10 is now available from http://nexi.com/nuance and fixes the crashing problem when hitting Reset on Windows 7 clients. I think this is the last known bug. Please let me know if there are any other bugs.
Chris: All of the alterations happen simultaneously. So if you change blue->green and change green->yellow, only original greens will be yellow. Of course there will be some bluish-greens that are yellowish because Nuance must blend the effects so there is no hard line between them.
About the feature request: Double-clicking on the slider labels should reset them to zero. Or is there another place you'd like to double-click?
ChrisC
ram: 8 GB DDR3
Post by ChrisC »
THANKS, reset now works without crashing ASP
regarding the double-click reset:
  • *) slider label -> works fine
    *) slider knob -> no reset - but would be nice, because if you drag it and don't like the result
    this would be a fast way to reset it
    *) colour patch button -> a new idea: a double click could reset all values from this patch
Also thanks for the quick bugfix. :D
madsec
operating_system: Linux
System_Drive: N/A
motherboard: Macbook 5.1 - Intel based
processor: Core 2 Duo 2.0 GHz
ram: 8 GB
Video Card: Nvidia Geforce 9400 Go
Monitor/Display Make & Model: Macbook 5.1 - 13 inch
Post by madsec »
CPU usage issue is fixed, thanks very much!
claudermilk
Post by claudermilk »
I was using 1.0.9 this weekend on my Win7 64-bit with no troubles.
I never really got what the old Brenda plugin did so didn't use it much. I grabbed Nuance Pro partly to support Sean, and partly because the examples in this thread and the new web page showed the potential power. I still have only scratched the surface, but I'm starting to get how to use the plugin. It really helped with a number of images that ASP was having trouble with. It was able to tone down some slightly overexposed faces where the more typical ASP adjustments just made a nasty yellow splotch.
Bibble transplant
seanmpuckett
System_Drive: N/A
If you have any suggestions on how to better convey Nuance's utility I'd love to hear them. I find it terribly difficult to explain how it works and what it's for because it is so non-obvious when it is working properly.
claudermilk
I think it was probably more on my end with not getting it. I read your original post here and then read the plugin page on your site a couple of times. It started to make sense to me, then playing with the plugin some more I had my aha moment. It really helped to pick a color (in my case I picked 14: White) and make a radical change; then toggle the patch palette & the overall plugin on & off a couple of times. Now I see what the effects are; this can be a very subtle tool so I think it takes a while with experimenting to get it. I know I've only just scratched the surface of what it can do since I was only using the Light slider to try to help recover some highlights without the nasty artifacts the stock ASP controls produce.
Bibble transplant
ChrisC
ram: 8 GB DDR3
Post by ChrisC »
seanmpuckett wrote:About the feature request: Double-clicking on the slider labels should reset them to zero. Or is there another place you'd like to double-click?
After using Nuance very often the last days I really miss the reset by double-clicking the 'knob'. This is a normal behaviour in all other ASP controls and very handy.
Any chance you could add it?
Chris
ferdinand-paris
motherboard: GA-X58A-UD3R
processor: 3.20 gigahertz Intel Core i7 960
ram: 4Gb
Video Card: NVIDIA GeForce 7300 GS
sound_card: Realtek High Definition Audio on-board
Hard_Drive_Capacity: 2500 Gb
Monitor/Display Make & Model: Eizo CG222W
Post by ferdinand-paris »
[I wonder how it was removed in the first place, not that I'd want to.]
What you can do is double click on the name of the slider, e.g. Colour, Tint, Light, etc which will also reset the associated slider.
F_P
