[plugin] Nuance Colour Grading tool released!
AfterShot Pro Plugins
seanmpuckett
operating_system: Mac
System_Drive: N/A
Re: [plugin] Nuance Colour Grading tool released!
Post by seanmpuckett »
The colour picker, I hope te restore in a later release. Thanks!
I create plug-ins for AfterShot Pro! See http://nexi.com/afplugs
bananahead
motherboard: Asus P67
processor: i7 2600k
Video Card: Nvidia 650
sound_card: Asus DX
Hard_Drive_Capacity: Lots
Monitor/Display Make & Model: NEC PA272W
Post by bananahead »
bananahead wrote: However you have a bug. If you switch on the History display and just make some random changes (to build up a history) then when you click anywhere in the history you get "Initial Settings" applied. Try one of your presets with History displayed and you should see it straight away.
Please can we have a fix for this?
(tintin had the same problem in zFrame)
MeneM
operating_system: Linux
System_Drive: Z
motherboard: Multiple computers
processor: Intel
Video Card: Nvida 3GB and amd and Intel
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Laptop 17" and Desktop 24"
Post by MeneM »
Hi! The Nuance plugin works correctly with me, but the presets dont?
They contain this instead of actual settings:
Code: Select all
bopt:Nuance.Nuance_settings="#_WH_HP_IA_BL_Tp^yN_eY`??_??_??;#_ia_IW_JT_J`_eY^yN_eY`??_??_??;@__E^{t^qC_bE_XX^hW_rL`??_??_??;#_Zg^ur_Lo_EY_C^^kr_eY`??_??_??;#_b]_Dh^nz_KI_Dp_MD_eY`??_??_??;#_lJ^j[^~m_KI^pQ^pQ_eY`??_??_??;@_fd_T~_eg_Or`P?_??_eY`??_??_??;#_X`_EB^cT_G|_FB_He_eY`??_??_??;@_`A_]__In_FB`P?_??_eY`??_??_??;#_Ri_La^q[_Ac_GS_G|_eY`??_??_??;#_mG^pU_ch_IN_eY^[I_eY`??_??_??;@_me_KA_jd_G|`X[_??_eY`??_??_??;#_QY_KE^\d_Dp_Fk_G|_eY`??_??_??;#_bS^ey_TT_Iw_FB^dG_eY`??_??_??;@_Yw_cK_Qb_Bu`@z_??_eY`??_??_??;@_so_Ad_qW_GS`i@_??_eY`??_??_??;#__v_^y^va_He_]m_Tp_eY`??_??_??;#__?^mR^lh_J`^{r_FB_eY`??_??_??;@`??_??_??_r{_\o_Ug`Kr`??_RL_fk;#_rL_??_??_He_YN_RL_eY`??_??_??;#_eY_??_??_KI_RL_J`_eY`??_??_??;#_Xe_??_??_DG_J`_Bu_eY`??_??_??;@_Kr_??_??^HV_??^ns_kI`??_??`WS;@_??_??_??_??_??_DR`??`??_??^dG;"/>
Nikon D7000, Ubuntu Linux 64Bit installed on /
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
Please reread previous posts....
cheers
afx
MeneM
System_Drive: Z
processor: Intel
Post by MeneM »
I do not understand? I have 107 installed? I cannot see a definite solution in the previous posts?
Thanks,
Mark
MeneM
System_Drive: Z
processor: Intel
Post by MeneM »
Ah now I understand, I need version 108, which is available on the corel plugin site, and not from Sean's page where you pay for the full version... Makes sense ;-P
madsec
System_Drive: N/A
motherboard: Macbook 5.1 - Intel based
processor: Core 2 Duo 2.0 GHz
ram: 8 GB
Video Card: Nvidia Geforce 9400 Go
Hard_Drive_Capacity: 750 GB
Monitor/Display Make & Model: Macbook 5.1 - 13 inch
Post by madsec »
Thanks very much for upgrading this plugin!
Though I think there is a bug in the plugin, similar to the bug tintin had in his plugin zFrame. Please have a look in this thread for more information: http://forum.corel.com/EN/viewtopic.php?f=90&t=45421
In short: with the plugin installed I get maximum CPU usage by browsing through the catalog. The algorithm which rebuild the preview images is caught in a loop and causes the CPU overload. If you need more information then please let me know! Also you may contact tintin to ask for his solution sice he fixed the bug in zFrame, maybe the cause is the same.
seanmpuckett
System_Drive: N/A
MeneM> Thanks for letting me know that my site didn't have the 1.0.8 version; it does now. There's too many places to post these plug-ins around the web now. It's one more thing to forget.
madsec> I'll look into the 100% issue, thanks for the tip.
Ianr> I'd love to bring Claire back. It all depends on whether plug-in sales ever get back to the level they were in B4 or not.
bananahead> I'm looking into this but I'm not optimistic that history is going to truly work properly until an underlying settings bug in ASP is fixed. If I can at least stop it from barfing "Initial Settings" all over the place that'll be something.
Thanks.
hannes_hab
System_Drive: Z
motherboard: ASUSTeK P8H77-I
processor: Intel Core i7 3770K 3.5 GHz x 8
ram: 16 GB
Video Card: AMD Radeon R7 200 Series
sound_card: Radeon HD 7700 7800 Sapphire
Hard_Drive_Capacity: 2x250GbSSD
Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
Corel programs: AfterShotPro 1, 2, (3)
Post by hannes_hab »
hello Sean,
any chance to port "Dinky" to ASP?
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
seanmpuckett
System_Drive: N/A
Version 1.0.9 of Nuance is now available from my site at http://nexi.com/nuance as well as on the Corel site. Main change for this version is a fix for the history bug. There's now more clarity in the history about what's changed and you can easily step around without Nuance corrupting the history. Also, and related, the currently selected patch no longer clears when you change images. This might clear up some CPU usage problems, although I've never seen them so I can't be sure. Let me know how it works for you!
elslunko
System_Drive: S
Post by elslunko »
The CPU issue seems to have been fixed, thanks! Buying now.
herman
motherboard: MSI P67A-GD65 B3
ram: 16 GB
Video Card: MSI GeForce GTX 460 Hawk 1024 MB
sound_card: on-board
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Eizo EV-2333W
Post by herman »
I am sorry I have to report this....
Version 1.0.9 crashes on my system (Win7 64 Ultimate)
All I have to do is open an image, open the Nuance panel and click reset.
Windows then tells me AfterShot Pro has stopped working.
As no-one else reported this so far I must have something unique here?
Everything works as advertised with version 1.0.8
I will be happy to provide you with more details if necessary.
Enjoy!
Herman.
charlot
motherboard: Dell xps8300
processor: i7 26
ram: 16gb
Video Card: amd Radeon HD6770
sound_card: on motherboard
Hard_Drive_Capacity: 2to
Monitor/Display Make & Model: Dell Ultrasharp U241
Post by charlot »
Same problem with Win7 when click on reset button ,other functions seem to work properly (pro version 1.09)
When will the color picker be implemented?
Cheers
Charlot
gareth
operating_system: Windows 8.1
motherboard: Acer Aspire TC-605
ram: 12Gb
Video Card: NVIDIA GeForce GTX 745
Hard_Drive_Capacity: a few TB
Monitor/Display Make & Model: AOC 2369M sRGB
Post by gareth »
1.0.9 W7 32bit does not crash on a simple reset for me.
ex-Bibble - mostly OLY E-510 and E-M5 + Win 8
elslunko
System_Drive: S
Post by elslunko »
Does not crash on Ubuntu 12.04 64bit.
