zFrame (v3.2.0)
AfterShot Pro Plugins
ChrisC
motherboard: Intel HM65
processor: Intel Core i7
ram: 8 GB DDR3
Video Card: AMD Radeon HD6770M
sound_card: Beats Soundsystem
Hard_Drive_Capacity: 750 GB
Monitor/Display Make & Model: HD+ High-Definition LED HP BrightView Display
Re: zFrame (v3.2.0)
Post by ChrisC »
Just took a folder with some of this bigger images (1 JPG is around 11 MB).
I made a copy of the folder and reduced the size of the JPGs down to 1 MB.
Then I applied the settings for zFrame (zShadow, zText) and startet an output batch (JPG 85%).
The 34 images from the 'small folder' got processed in a few minutes.
The 34 images from the 'normal size folder' gave no output (stops at 0 of 34).
XMP where the same.
If I send only one image of the 'normal size folder' to the output batch it gets processed.
If I send two images of the 'normal size folder' to the output batch -> no result - stops at 0 of 2.
So I think I exceed a magic limit here.
2012-11-24=18-14-33-400=zuHause-BlickAusDemFenster-BrandGegenüber.jpg.xmp
(15.95 KiB) Downloaded 543 times
Trucks
operating_system: Linux
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Eizo S2243 W
Re: zFrame (v3.2.0)
Post by Trucks »
i got nearly the same, i reduce Preferences/Performance/Batch Items in Flight to 1 and its better. Maybe it helps.
Trucks
ChrisC
ram: 8 GB DDR3
Re: zFrame (v3.2.0)
Post by ChrisC »
Thanks Trucks
Good point - I will give it a try in the evening and report back.
ChrisC
ram: 8 GB DDR3
Re: zFrame (v3.2.0)
Post by ChrisC »
Thanks again - that did the trick :)
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Re: zFrame (v3.2.0)
Post by Trucks »
Great but i think thats not a feature...
Trucks
hannes_hab
System_Drive: Z
motherboard: ASUSTeK P8H77-I
processor: Intel Core i7 3770K 3.5 GHz x 8
ram: 16 GB
Video Card: AMD Radeon R7 200 Series
sound_card: Radeon HD 7700 7800 Sapphire
Hard_Drive_Capacity: 2x250GbSSD
Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
Corel programs: AfterShotPro 1, 2, (3)
Re: zFrame (v3.2.0)
Post by hannes_hab »
ChrisC, tintin, Trucks
ChrisC
.. If I send more than one image to the output batch the PC is getting very hot seems to work real hard ...
... reduce Preferences/Performance/Batch Items in Flight to 1 ...
Trucks
has anything changed about the problem with the new stable version?
Any advantage with the new version?
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Re: zFrame (v3.2.0)
Post by Trucks »
no, i use the .30 Version with and without this settings. Sometimes it works sometimes i had to use the normal settings.
Trucks
hannes_hab
System_Drive: Z
ram: 16 GB
Re: zFrame (v3.2.0)
If there is no advantage - so why you are use the latest version?
regards Hannes
austria
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Re: zFrame (v3.2.0)
Post by Trucks »
- No Risk, No Fun
- Betatester (since Corel it makes no sense)
- No Pro
- I hope the version is better
hannes_hab
System_Drive: Z
ram: 16 GB
Re: zFrame (v3.2.0)
* hope it will make sense again
* hoping a version will come with real advantages - like watched folders (a feature we already had) , better rename ..., better DAM, new cameras ...
good luck to all of us
regards Hannes
austria
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Re: zFrame (v3.2.0)
Post by Trucks »
Maybe they thought, "why the heck should we bring a new version when the world goes down at 21.12.12?".
mikmak
Re: zFrame (v3.2.0)
Post by mikmak »
I have the same problem with the new version 1.1.0.30 of ASP. If I try to use zframe on files from Canon 50D or Olympus OM-D the batch process stops completely, even if I only try to develop 1 file. If I clear the cache and restart it sometimes works again. It works ok with smaller files from Olympus E-P1 and Canon 5D.
Regards
Per
ChrisC
ram: 8 GB DDR3
Re: zFrame (v3.2.0)
Post by ChrisC »
hannes_hab wrote:ChrisC, tintin, Trucks
No! After the 'trick' with reducing the batch items in flight to 1 didn't work any longer I tried the new version 1.1.0.30. -> same result!
As soon as I define an output batch which includes zFrame the batch never finishes (I only try to put one small frame around the picture).
zShadow and zText slow down the output - but at least the batch gets finished
At the moment I have to forgo zFrame :cry:
ubuntuuser
System_Drive: N/A
Re: zFrame (v3.2.0)
Post by ubuntuuser »
I have the problem with zPerspector, using AfterShot vers.: 1.2.0.7 and a Sony RX 100. Unfortunately I cannot downgrade, because the Sony RX100 is not supported. The only chance I have, is to use ^F and calculate picture by picture. A batch of 2 photos doesn't end, sometimes it ends after 5-10 minutes for 1 picture.
Code: Select all
0.701: AfterShot vers.: 1.2.0.7
0.701: Built on: "Fr. Jun 28 2013"
0.36: Warning: slow tiles used because plugin is not white listed:  "zPerspector"
0.58: Warning: slow tiles used because plugin is not white listed:  "zText"
Identifier: tin.tin.zPerspector
   Version: 2.0.1
      Path: <User Home>/Plugins/zPerspector.afplugin
Identifier: tin.tin.zText
   Version: 2.3.2
      Path: <User Home>/Plugins/zText.afplugin
10.834: Registering AfterShot plugin...  "zPerspector"
10.834: zPerspectorFilter   loaded. group_id  2
10.834: zGridFilter         loaded. group_id  2
10.834: Registering AfterShot plugin...  "zText"
10.835: 13 :  "zPerspectorFilter"
10.836: 35 :  "zTextFilter"
tintin
processor: Ryzen R5 3600X
Re: zFrame (v3.2.0)
Post by tintin »
ubuntuuser wrote:I have the problem with zPerspector, using AfterShot vers.: 1.2.0.7 [...]
see also here.... http://forum.corel.com/EN/viewtopic.php ... 89#p283189
my plugins on the official plugins homepage
If you find my plugins helpful, please make a donation to support further developments - just click here, thank you!
