Grad Filter needed
greerd
- System_Drive: Z
- processor: Intel i7 920
- ram: 12 GiB
- Video Card: nVidia GeForce 260
- sound_card: Onboard
- Hard_Drive_Capacity: 5 TB
- Monitor/Display Make & Model: Dell UltraSharp U2410
Re: Grad Filter needed
Bought and downloaded, thank you for the effort.
Thank you very much! Made a quick post about it on my blog. When I saw the lighting conditions at the wedding a couple of weeks ago I knew I'd need the gradfilter for some of the wider shots.
http://www.edltphoto.com/gradfilter-pro-aftershot-pro/
mindsocket
- System_Drive: N/A
- ram: 8Gb
Thanks all for the positive feedback, I'm glad it's making a difference for everyone
- Roger
Thanks elslunko, that example before and after shot shows a huge difference.elslunko wrote:Thank you very much! Made a quick post about it on my blog. When I saw the lighting conditions at the wedding a couple of weeks ago I knew I'd need the gradfilter for some of the wider shots.
- Roger
Just bought. Thank you.mindsocket wrote:Thanks all for the feedback. The plugin is now available for new users: http://bit.ly/gradfilter Spread the word!
Ralf (with beers from Berlin, Germany)
WilsonC
- Monitor/Display Make & Model: Samsung SA300
Just one quick question (which I think I already know the answer to, but I'll ask anyways), is there a way to create a "Reverse GND" filter with this new plugin?
-Christopher
You can if you check "brighten" and change the color to white.WilsonC wrote:Just one quick question (which I think I already know the answer to, but I'll ask anyways), is there a way to create a "Reverse GND" filter with this new plugin?
WilsonC
That's a really exciting technique that will come in handy for sure! But what I'm talking about is a GND filter where it is darkest in the center and then fades up to the top (see link: http://ecx.images-amazon.com/images/I/2 ... AA300_.jpg). A lot of people use these for taking pictures of sunsets, where the brightest part of the image is near the middle of the frame. Does that make sense?elslunko wrote:You can if you check "brighten" and change the color to white.WilsonC wrote:Just one quick question (which I think I already know the answer to, but I'll ask anyways), is there a way to create a "Reverse GND" filter with this new plugin?
-Christopher
madsec
- System_Drive: N/A
- motherboard: Macbook 5.1 - Intel based
- processor: Core 2 Duo 2.0 GHz
- ram: 8 GB
- Video Card: Nvidia Geforce 9400 Go
- Hard_Drive_Capacity: 750 GB
- Monitor/Display Make & Model: Macbook 5.1 - 13 inch
Didn't try it, but I think you can use two filters, one for doing the soft ege and one for the hard edge, and they meet in the center of the image...
WilsonC
That's actually not a bad idea, and it got me thinking. The best solution I've found so far (inspired from your post) is to create a soft edged filter on an Adjustment Layer, rotate it 180 degrees and then increase the offset. Then use the polygon tool to cut the filter out of the bottom portion of the image. Using the polygon tool's Feather adjustment, you can actually control the hardness of the dark portion of the filter. Cool!
-Christopher
madsec
- System_Drive: N/A
- ram: 8 GB
I'm glad I could help
Will try your idea sometimes!
Grad Filter: finally ported to AfterShot Pro
Hi all,
I have been waiting a long time for this good news.
Gradfilter is a brilliant plugin which I used very often with Bibble and which fortunately now is also available for AfterShot Pro. One back draw has always been the "pink color cast" bug when you applied the highlight recovery on board of Bibble / Aftershot Pro or when you activated the grad filter effect. After that nasty bug has been addressed, the usage of GradFilter should now open up a few options with certain images (e.g. nature captures with very light skies or difficult and unbalanced light distribution).
After 5 minutes of playing around I uploaded two images to illustrate the effect of e.g. two grad filters applied http://flic.kr/s/aHsjzPjRDE
Cheers,
d-light
Cheers,
d-light
WilsonC
Nice example d-light! This is definitely gonna be one of my most used plugins. It's really useful for controlling were the viewers eye is drawn to. Here's a quick example I came up with as well (it is super subtle, so I recommend Ctrl+Clicking each image in a separate browser tab so you can flip back and forth to see the effect easier). I've found that using the Grad Plugin on an adjustment layer, and setting the grad to brighten you can Dodge away parts of the image using the region tools (like lightening the tree of the left of this train image).
Without Grad:
With Grad:
With Grad, plus Brighten Grad on tree to the left (not a perfect selection):
Without Grad:
With Grad:
-Christopher
Thanks for your feedback Christopher! I see we both consider Grad to be a very useful tool
Your photo shows a quiet 'dramatic' sky even without Grad applied. However, using the graduated filter effect the clouds seem to be even more apparent (e.g. in the right hand side of your image). As you say - subtle but visible.
Cheers, Michael
Cheers, Michael
VIM
- motherboard: Dell Inc. 0G3HR7 A00
- processor: 3.60 gigahertz Intel Core i5 680
- Video Card: ATI Radeon HD 5450
- sound_card: Creative SB X-Fi
- Hard_Drive_Capacity: 10TB
- Monitor/Display Make & Model: Dell ST2410
I'm unable to find the plugin on the Corel Plugin webpage
