How do I use history to restart editing from a certain point
twm47099
motherboard: HP 0A68h
processor: Intel Core 2 Duo
ram: 2GB
Video Card: NVIDIA Quadro NVS 285 128MB
sound_card: RealTEK HD Audio
Hard_Drive_Capacity: 410GB
Monitor/Display Make & Model: EMA e15t4
Post by twm47099 »
Sometimes when I process an image (starting with a raw) I decide I'd like to make a second version using using different noise reduction, sharpening, or making a B&W in addition to a color image, etc. But I may have sent some time straightening and cleaning followed by setting exposure and don't want to repeat those steps.
In some programs, I make a new version, and then go back and clear out the steps in history going back to the ones I want to keep. I can't seem to do this in ASP. I expect that I am doing something wrong. How could I do that?
Thanks,
Tom
bananahead
motherboard: Asus P67
processor: i7 2600k
Video Card: Nvidia 650
sound_card: Asus DX
Hard_Drive_Capacity: Lots
Monitor/Display Make & Model: NEC PA272W
Re: How do I use history to restart editing from a certain p
Post by bananahead »
Choose View and then History.
You can then click on any point in the displayed History window to go back to any stage.
DocBrown
Post by DocBrown »
There is a small caveat to this if you use File System Mode. The history is only saved for your current session. To keep a full running history of all your edits, you need to be making them from within a catalog.
Chuck
Lightroom 4.1, ACDSee 5 Pro, Neat Image 7, PictoColor iCorrect One Click
Canon EOS 20D, Canon EOS 7D
Visit my gallery: http://coldwater.smugmug.com/
larschristian
operating_system: Linux
System_Drive: N/A
motherboard: ASUS something
processor: AMD Phenom II X6 1090T Processor
Video Card: ATI radeon something
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Dell 2312HM + Samsung SM913v
Post by larschristian »
I havn't used the history window for a long long time. In Bibble I could jump back and forward in the history. Now in ASP new history clears when I jump back! As soon as I jump back in history the newer history is cleared and there is a new step say "reset color". Is this an ASP problem or is is caused by a bad behaving plugin? :shock: :evil:
twm47099
ram: 2GB
Post by twm47099 »
Thanks, but I'm not sure I've got it.
What I want to do is keep the original version, make a second version and on the second version go back to the step I want to keep (such as straightening) and then continue processing the second version from there.
When I created the second version, the history showed nothing in it, although that version was obviously processed.
The original was imported into ASP.
I'm doing something wrong, so any additional help would be appreciated.
Thanks again,
Tom
bananahead
processor: i7 2600k
sound_card: Asus DX
Hi Tom
When you create a new version from current it doesn't inherit the history.
What I do is - when I get to a point that I want to save - create a new version as the save point and then go back and make other changes to the original.
Cheers
Nigel
lundbech
System_Drive: N/A
motherboard: HAL 9000
Post by lundbech »
bananahead wrote:Hi Tom
It would be nice if you were able to browse history, but once you enter history you cannot go back to the future. So you have to make copies as you go along. Not the best solution. Having the possibility to browse the history (like in Darktable) and return would be very nice!
Autark
System_Drive: B
ram: 3GB
Post by Autark »
You can go back in history to the last desired edit and create a new version from that point, and then move forward to the current edit again. It is indeed unfortunate that the new version will not inherit the version history of the master.
It would be very handy to have a context menu item on each history item to create a new version from that.
RickHeath
Post by RickHeath »
Autark wrote:You can go back in history to the last desired edit and create a new version from that point, and then move forward to the current edit again. It is indeed unfortunate that the new version will not inherit the version history of the master.
The history is still there - just it is in the original master version. Although I agree it could at times be handy to have the option of having the history in the new version. It is worth noting that in ASP, unlike in more "traditional" pixel editors, it generally doesn't matter what order you do a sequence of adjustments the end result will be the same.
If you want to go back in the history beyond the state where you created the version you would currently have to do it by making a new version from the master at that earlier state. And you can use selective copy & paste between versions if there is something you want to get from one to the other without doing all the settings by hand (for example, all the settings of a particularly complex plugin).
Regards
Rick.
larschristian
System_Drive: N/A
lundbech wrote: It would be nice if you were able to browse history, but once you enter history you cannot go back to the future. So you have to make copies as you go along. Not the best solution. Having the possibility to browse the history (like in Darktable) and return would be very nice!
Found in another thread that there is a confirmed bug in the zFrame plugin which causes a "Reset color" event that clears newer history. Tintin says it will be fixed in the next version. :)
kaymann
motherboard: ASUS P8P67 PRO REV 3.1
processor: Intel i-7 6800K
ram: 32 GB
Video Card: NVidia GeForce RTX 2060
sound_card: Onboard
Hard_Drive_Capacity: 3.5 T
Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
Post by kaymann »
And the zFrame also causes the 100% CPU problem.
B4b5
Post by B4b5 »
kaymann wrote:And the zFrame also causes the 100% CPU problem.
I think tin.tin has it here-> http://forum.corel.com/EN/viewtopic.php ... 25#p240625
kaymann
ram: 32 GB
sound_card: Onboard
Post by kaymann »
Yes, it is awesome and I am continually amazed at how quickly and responsessive the plugin folks are - they are certainly deserving of our donations....
