Dead slow, CPUs running at 100%
-cr
operating_system: Linux
System_Drive: N/A
Re: Dead slow, CPUs running at 100%
Post by -cr »
madsec wrote:Have you installed the new "Nuance" plugin? Have experienced the problem with this plugin installed, but didn't test it well enough to be sure yet.
You can try to start ASP without plugins by renameing the plugin directory in the ASP location on your hard-drive. If the problem remains, than you can be sure that the problem comes from ASP itself.
Yes, I've installed the new "Nuance" plugin.
I'll try to reproduce the problem without plugins when I find some time for that.
I'd hate having to find out *which* of all the plugins is to blame, though (if any). :/
madsec
System_Drive: N/A
motherboard: Macbook 5.1 - Intel based
processor: Core 2 Duo 2.0 GHz
ram: 8 GB
Video Card: Nvidia Geforce 9400 Go
Hard_Drive_Capacity: 750 GB
Monitor/Display Make & Model: Macbook 5.1 - 13 inch
Post by madsec »
If the Nuance plugin isn't the problem, then you should first remove all plugins from the plugin folder by once to see if the problem is realy plugin related. If it's so you can move the plugins back into the folder one by one, shouldn't last to long since the problem is easy to provoke, in my case anyway...
-cr
System_Drive: N/A
Post by -cr »
OK, in a quick test with just the Nuance plugin removed, I haven't been able to reproduce the problem.
It'll require a longer editing session to convince me that this problem really is caused by Nuance only, though. I'll get to that later.
madsec
System_Drive: N/A
ram: 8 GB
Post by madsec »
Reported the bug to the author of Nuance, lets hope he will find the bug...
madsec
System_Drive: N/A
ram: 8 GB
Post by madsec »
The Nuance plugin is fixed as well, here is the link to the updated download:
http://nexi.com/nuance
