Copyset is loosing settings
Cootje
Post by Cootje »
Hi All,
I'm just in the first weeks of using ASP, so not sure if I'm missing it or ASP...
In my workflow I´m changing my metadata in two steps:
Step 1) Add general metadata to all images, like: Copyright, Maker, etc...
Step 2) Add specific metadata to a group/project, like: Headline, Location, Keywords, etc..
I got the impression that you can't add metadata to a selection of images directly!?
So, I tried to use the copysets. Introduced some new copysets with the setting, but I noticed that ASP only keeps these setting during the session. If you close ASP and start later, the setting in the copysets are missing!?
Question:
- Anybody noticed this behavior with copysets?
- Is my conclusion on adding metadata on a selected group right?
Thanks for your advice,
Co
B4b5
Re: Copyset is loosing settings
Post by B4b5 »
Cootje wrote:Question:
Co
Hi Cootie; You know best , exactly what buttons you're clicking...
Check this post - some of it may be helpful to you. -> http://forum.corel.com/EN/viewtopic.php?f=90&t=45373
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
If copy sets are not persistent between sessions, then you have a permission problem.
check the permissions of the CopySets directory in your AS user folder.
cheers
afx
Dutchmm
System_Drive: N/A
motherboard: Asus 97
processor: Intel i7 4785T
Video Card: Onboard Intel
sound_card: Intel AC97
Hard_Drive_Capacity: 2.5TB
Monitor/Display Make & Model: Philips 28"
Corel programs: ASP 3 Pro (and 2 and 1 before)
Post by Dutchmm »
Cootje wrote:Hi All,
[snip]
Co
I don't think that your conclusion is right - at least for keywords. I just selected three photos of a new dress my wife had bought, and was able to add the words "New Dress" into the keyword panel once to cover all three. If I then select each photo, the words show up on all of them. The keywords don't flow automagically into the keyword browser, though, if that was what you mean.
HTH
Mike
Cootje
Post by Cootje »
Henry, Afx, Mike,
Apologies for the delayed reply, was away for some days. Thanks for your thoughts.
I noticed I can copy the metadata using the copysets I made, so it looks like the problem is solved... But the funny part is that when I want to edit an existing copyset, specific settings are not visible (in particlar the IPTC settings)... Most important, it works...
Mike, you are right. You can add keywords to a group of images when they are selected. For me it is still strange - not productive - that you can't do the same for other metadata fields (IPTC)... For me the copyset approach is a workaround...
Thanks again,
Cootje
