PartlyFraenzken wrote:... one question to afx and the other beta testers (concerning the hopefully forhcoming new version): Are you still smiling?
Waiting for the next beta drop to get the smile level up.
cheers
afx
Ok, that sounds like a sane base.Zarastro wrote:Geeqie, GIMP and B5.I used to use Gwenview for viewing images, but as I've started to use ProPhoto RGB I've learned that Gwenview doesn't do CM and thus changed to Geeqie.
AS uses a newer version of Qt. Might be a reason.Maybe, but this never happened in B5 for any of the plugins I had. And now it's happening on ASP.afx wrote:The joys of video drivers on Linux....
The latest is 295.20I don't think so. This happens for every MRW file I open on ASP (and B5). Sometimes I shoot RAW+JPEG and then the JPGs appear instantaneously. MRWs on the other hand just appear with the [X] box in the thumbnail view and take long seconds to finally appear on the thumbnail viewer and in the image canvas. And anyway, I'm using the official NVidia drivers on my system - the latest release, 295.17.afx wrote:Check again. I bet you are doing something else that triggers this, like crop or regions. Yet another issue that typically points to a video driver problem.4. Rendering of a Maxxum 5D 6MP RAW on the UI is much more slower than the rendering of an A700 12MP RAW. However, when writing the actual processed files on the disk, the rendering time is as it "should be" - that is, 6MP is much more faster than 12MP.
Heh. Just started using ProPhoto RGB because somebody in the old B5 forum said me that "exporting with ProPhoto" would preserve the maximum color gamut even for JPEGs. Anyway, I can't really see the difference when the profiles are converted, and thus it will be fine for me.afx wrote:Ok, that sounds like a sane base.Zarastro wrote:Geeqie, GIMP and B5.I used to use Gwenview for viewing images, but as I've started to use ProPhoto RGB I've learned that Gwenview doesn't do CM and thus changed to Geeqie.
With one caveat though, don't use ProPhoto on JPGs... 8bis/Channel is too tight for that gamut.
I sure can't find it anywhere in ASP's forums. And the search function blocks common words such as "option".afx wrote: Did you see that comandline flag to change the rendering method? I keep forgetting the name, it was posted a few weeks back.
Send me a PM with an e-mail address and I'll then share it with you via Google Docs. I can't upload the image to ImageShack.afx wrote:Could you post that Camera JPG somewhere? I'd likt to try and reproduce the effect on my boxes.
That's why I'm mentioning it, since I don't understand why Max5D MRWs take longer to be rendered since they are actually smaller than A700's ARWs.afx wrote:That sounds extremely weird. The base pipeline is the same for on screen and to file rendering, just that on screen it gets usually downsampled.
It seems that there is nothing unusual, and JPEG files always rendered correctly on B5. Also the problem happens only with JPEG files, not the raw ones. About camera settings, I've never had to change anything on B5. Gzipped log follows (this site does not allow .log files.afx wrote:Anything interesting ion the log file? A camera specific default setting that you don't remember setting up?
Went there, checked that. At first, it seemed that soft-proofing was the culprit, as it was active and set to SMPTE-C. Turning it off seemed to solve the histogram problem.spoilerhead wrote:my experience with colors in ASP looking strange where all very similar and easy to sum up:
* i used the wrong screen profile
when i used the same profile as in Gimp (as my reference CM Viewer) results where virtually identical. Make sure soft-proof is off, too
As soon as you try to edit or post them online this will lead to trouble. You might want to follow the sRGB link in my signature....Zarastro wrote:Heh. Just started using ProPhoto RGB because somebody in the old B5 forum said me that "exporting with ProPhoto" would preserve the maximum color gamut even for JPEGs. Anyway, I can't really see the difference when the profiles are converted, and thus it will be fine for me.
Improve your searching skills, you must.....I sure can't find it anywhere in ASP's forums. And the search function blocks common words such as "option".afx wrote: Did you see that comandline flag to change the rendering method? I keep forgetting the name, it was posted a few weeks back.![]()
afx on afximages.comSend me a PM with an e-mail address and I'll then share it with you via Google Docs. I can't upload the image to ImageShack.afx wrote:Could you post that Camera JPG somewhere? I'd like to try and reproduce the effect on my boxes.
Yup, looks normal....It seems that there is nothing unusual
yeah, that site needs loads of loving...Gzipped log follows (this site does not allow .log files.)
... must look funnyafx wrote:PartlyFraenzken wrote:... one question to afx and the other beta testers (concerning the hopefully forhcoming new version): Are you still smiling?
cheers
afx
