Zarastro wrote:1. JPEGs are rendered differently than shown on ASP's UI. This should happen for all JPEGs, but I've clearly noticed the differences when processing images took on an overcast day. The UI insisted presenting the sky with light cyan tones on the UI, while in the processed JPEGs it is shown as it should: gray. This happens both for the Maxxum 5D and the A700.
What are you using to view the JPGs?
2. UI sometimes does not update correctly and then the settings of the tool panels disappear. When I minimize/maximize ASP then the UI is correctly redrawn. Happens more when I use the plug-ins, normally zPerspector.
The joys of video drivers on Linux....
3. Colors are over-saturated when opening in-camera processed JPEG files (A700 and Maxxum 5D). I must turn the saturation slider to -30 to get a normal look on the images, and sometimes not even this makes the images look normal.
Hmm, unless you did something to change the defaults for rendered images, this sounds like a color management problem?
Do you have a calibrated screen and have AS set to use the Monitor profile?
4. Rendering of a Maxxum 5D 6MP RAW on the UI is much more slower than the rendering of an A700 12MP RAW. However, when writing the actual processed files on the disk, the rendering time is as it "should be" - that is, 6MP is much more faster than 12MP.
Check again. I bet you are doing something else that triggers this, like crop or regions. Yet another issue that typically points to a video driver problem.
5. Images processed in ASP for A700 feel more brighter than B5 (see item 1). I feel that I'm more compelled to use HR or reducing exposure more frequently on ASP than in B5. This also happens with the Maxxum 5D.
Yup, AS is generally brighter than B5.
cheers
afx
