LeviFiction wrote:I'm also under the belief it might be the best way. Even if I do hate trying to get the elliptical just right (Not that it's hard...I'm just terrible at that sort of thing).
I'm so glad you said that because I've been hesitating about confessing that I'm stumped at that first step! How on earth do you get the ellipse to match the original in size and position?
(BTW, I've always found it a surprising weakness in PSP8 and earlier that it won't let you drag the selection marquee to adjust it. Even IrfanView supports this, although that only allows a rectangular selection. Is this limitation still the case in later versions?)
I would very much like to master flagpole's technique if I can get a pointer on how to do it please. It will be a skill that's useful in other contexts.
Since the background is black you could use the magic wand at a lower tolerance and hope that it selected a perfect oval. Doing a cut-and paste of your image, however, that does not seem to be the case. Whether there is something there or it's just JPEG artifacts I don't know. So I had to use the Levels command to darken up any remaining non-black values and then I could use the magic wand tool. So this added an extra step. To the overall process.
Ah, essentially that seems to be a more refined variation of the method I've been playing with myself earlier this morning. I've been getting reasonable results and it doesn't require precise manipulation. But I've tried this only briefly so I expect it has downsides I've not yet seen! Anyway, my steps were:
1. Expand the canvas
2. Use the magic wand with a low tolerance (say 10) to select the black background.
3. Invert it, thus selecting just the elliptical image.
4. Copy that and paste as a new image, i.e. the ellipse on a transparent background. (May be an unnecessary step.)
5. Return to the selected ellipse and expand it by say 30 px
6. Fill that with the border colour required, so you now have a solid ellipse a bit bigger than the original.
7. Copy/paste the temporary ellipse as a new layer into the larger solid ellipse, which is automatically centred.
Flagpole's method offers the most flexibility with minimal destruction so it's actually good that it has those "many" steps.
I can decrease it by maybe two or three at the most if I skip some of the best practices and assuming PSP8 had a levels command.
1) Increase canvas size - make sure selected color is also black.
2) Use Levels command ( I found that Black:22 Midtones:137 and White:255 worked nicely).
Can you describe how to access that Levels command please?
3) Use magic wand on black portion with a tolerance of 6.
4) Promote background layer and delete - Technically this step is optional but if you don't want a background it is recommended.
5) Invert selection
6) Select Selection Edges (In the Selections menu)
7) Fill selection
Apply drop-shadow.
The other option is to use a vector though this may result in you taking more time to get the vector correct and I don't recall how developed vectors were back in PSP8
1) Add oval vector and resize to fit current oval.
2) Set background to transparent and set the stroke color and size.
3) With "Use all layers" selected - select the original image layer and use the Magic Wand tool on the background.
4) Promote background layer to regular raster layer and hit delete to remove background.
5) Apply drop shadow to original image on its own layer.
Terry, East Grinstead, UK
